konica minolta c364e error C-E301
  • romario
    • Jun 2020
    • 192
    [Error Code] konica minolta c364e error C-E301
    Hello friends, i have a km with the error c-e301, erase data, uninstall the hdd and i worked one day the next day i got an error again, update the firmware to g20-m0, g20-m1, they are the only ones i have , and the error continues, someone can help me
    thanks
  • femaster
    • May 2011
    • 1492
    Re: konica minolta c364e error C-E301
    That is a very generic error with many causes. It would be hard to determine for sure what is going on with that. The firmware you have on the copier is supposed to include corrections to help prevent that error code from happening.
    I'd Start by looking in service mode, under firmware, and see what the SSD firmware is currently at. If I remember correctly it is found on the very last page.
    There was problems with the early firmware for the SSD that caused all kinds of issues, including the CE301. If the firmware is a real early version, it requires an update using the SSD Tool first before it will accept an update through the regular firmware updates. But, lets not get ahead of ourselves. Report back with what the current firmware version is on the SSD first and we can go from there.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4661
      There is a bulletin for this code. The special F/W that corrects it is: A61F0Y0-F000-GDH-M1
      • romario
        • Jun 2020
        • 192
        Hi friend, sorry for the delay I had to travel 9 hours from my workshop to look for km c364e with the error CE301, now the client told me that I had a power failure in his premises, the machine gave an error on the hard disk and adf , I sent him to disable the disk and adf so that it worked until he could travel, after 3 days the error returned I sent him the firmware A5C10Y0-F000-G20-M1 and A5C10Y0-F000-G20-M0 which are the only ones that I have, and chase the error, I already have the machine with me in my workshop
        ssd fw version: ver6.05m
        thanks
        • femaster
          • May 2011
          • 1492
          That would be the newest for the SSD, so you will have to look elsewhere. I'd see if you can get your hands on the firmware that Copyman has suggested (A61F0Y0-F000-GDH-M1) and see if that will resolve your error.
          • Cantechman
            • Nov 2008
            • 228
            I had that same error a few weeks ago on the same model and replacing the hard drive and updating to the latest firmware fixed the problem.
            • romario
              • Jun 2020
              • 192
              Hi. Correct but the problem is that I only have the firmware that I mentioned. Now if you can help me with that firmware I appreciate it. I tell you that today I try to load the firmware again and the machine only advances me up to 1 bar on the screen. I try to light normally and it follows me only to the first ignition bar
              thanks
              • romario
                • Jun 2020
                • 192
                Okok I'll try to do. If not, now the machine when starting only loads the first ignition bar of there is no happens
                thanks
                • Don N.
                  • Nov 2011
                  • 409
                  I would insure they have the latest KM print drivers, NOT windows drivers auto installed and not MAC default either. GO TO KMBS.KONICAMINOLTA and d/l the latest driver that fits the function ver. you are running. With G20-M1 FW, and Function ver set to 7 (ssw 25 HEX 60)
                  If drivers match function ver. and EVERY PERSON PRINTING HAS KM DRIVERS, then swap the HDD.
                  You may find cloud based doc's don't like windows drivers.
