Bizhub 364e letterhead & 2 sided?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Delivered this off lease machine. I initalized the machine and wiped all the settings when in the shop.
    Customer called a few hours later and said she put letterhead in tray 2 and set for letterhead. Tray 1 plain paper. When she sends a print job or copying from tray 2 it always pulls letterhead back in for two sided. If they change to plain paper it's fine and doesn't do 2 sided.
    I know the print drivers are factory set for 2 sided and I always change that to one sided but like I posted this happens when copying and printing.
    She changed some settings on the interface page and didn't help.
    Anyone ever see this? Hoping it's some simple setting so I don't have to drive 2 hours and spend another hour trying to find setting.
    Why does this stupid crap always happen to far away accounts
    Thanks in advance for any help.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub 364e letterhead & 2 sided?
    Konica always duplex letter head even if its only printing one sided. you cant turn that off.
    thats why i always i leave it on plain paper and just take it out of the auto tray selection list
    • Synthohol
      Certified Konica Expert
      • 5847
      it pre-warms the paper and flattens the fibers because traditional letterhead is on linen paper.
      if its regular white you can assign special paper to that tray and for 1 sided only if i recall.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        Thanks for the quick replies! Good information.
        Do you know if it will automatically duplex from by-pass tray?
        Learn something new everyday.
        Thanks again for the help.
        • Synaux
          • Mar 2012
          • 1224
          This is something I have never really thought about and subsequently always thought letterhead was a pointless setting. Thanks for reading the manuals far closer than me
          So duplex is not working or is this one observant operator?
          Here are some observations I formulated working in different fields over the years:
          Regarding running stocks that have a rough "paper-calendering," I have personally ran cases upon cases of such letterhead stock--linen/laid/parch/cotton/plastics/labels/odd glossy shit that should be ran on a press--if I ever had a problem, I just bumped it up to thick 1-4 (sometimes even second side). Rinse and repeat as necessary.
          Another trick I have used with nonstandard stocks is to add a blank page to the document with a dot outside of the printing boundaries (in case skip blank page is enabled and as long as the duplex section is functional [same method can be used for copies if needed].) of course this is not something to push on customers but it works quite well.
          Another trick with really stubborn stocks and/or stubborn solids (i.e., pure black/dark composites) is to print the job, then run it though the bypass again as thick 4 as a blank copy/running mode out of SM--really smooths it out.
          I know most of you are not in the actual printing industry (I used to be). These machines can be manipulated far beyond their intended use.
          • Synthohol
            • 5847
            every/any tray that is denoted as letterhead will auto duplex including the bypass
            • B0265
              • Jan 2007
              • 718
              The reason for this behavior is to ensure that the letterhead/logo is always printed on the front page regardless if you print 1 sided or 2 sided documents.
              • drowranger
                • Jul 2015
                • 122
                There is a way around by using media modifier IWS to print without this delay even letterhead selected by driver. But need extra memory and Web kit to install the IWS.
