Infamous Line of shame
  • cayyell
    • Feb 2013
    • 82
    I have a C452 having a faulty PH unit which makes the whole page magenta.
    After the replacement I was happily doing gradient adjustment then i get this even a demo print and counter list.
    then I tried multiple times of installation procedure however I cant get ok the non-image area erase check keep giving out ng2.
    By the way I dont remember seeing lines like this on counter list and demo print and even on the configuration page.
    Any suggestion?
  • Blizzoo
    • Aug 2013
    • 607
    Re: Infamous Line of shame
    Hi, check out this thread split vertical / horizontal lines on prints and copy documents.
    • Synthohol
      Certified Konica Expert
      • 5798
      turn off all the lights in the room to do the non image erase check.
      ive even made a tent with my coat over the raised ADF to cut out overhead light to get a successful adjustment.
      • cayyell
        • Feb 2013
        • 82
        Originally posted by Blizzoo
        I will try it out
        Btw the gradient chart looks freaking perfect as well as all the test print from service mode.
        Then i m gonna try it out with a tent, the other machine on the same room get a ok tho
        • cayyell
          • Feb 2013
          • 82
          Thanks for the link, it works well
          • Albonline
            • Sep 2008
            • 1144
            Any suggestion?
            these are not setup lines. there is something wrong with your print head or the connections to it!
            • tsbservice
              Field tech
              • 7973
              Hey, good eye Albonline. I didn't open attachments until your post. Totally agree with you now.
