Bizhub C552, HELP ME
  • potro_salvaje
    • Sep 2010
    • 23
    Hi guys, i have that line that comes out on the side of thesheet, sometimes it is cyan, sometimes magenta, I already changed drum/dev,of the 3 colors and nothing, any suggestion.
  • barber782
    • Aug 2011
    • 286
    Re: Bizhub C552, HELP ME
    What orientation is the paper going? As it could be transfer if its landscape
    Sent from my VTR-L09 using Tapatalk
    • copier tech
      • 8176
      [ATTACH=CONFIG]46400[/ATTACH]
      This is caused by the transfer unit.
      Most likely the image & dev units were ok.
      • potro_salvaje
        • Sep 2010
        • 23
        It is horizontally oriented, from Tray 1
        • Synthohol
          Certified Konica Expert
          • 5849
          Agreed. Looks like t-belt is not cleaning itself.
          • potro_salvaje
            • Sep 2010
            • 23
            U mean the transfer belt bias?
              no the rubber transfer belt not internal settings the mechanical component
              • barber782
                • Aug 2011
                • 286
                If you take out the transfer unit there might be a small shard of paper of fluff stuck in the cleaning unit. Or the belt is just worn. I sometimes take apart the itb cleaning assembly and clean it out just in case anything has become lodged in there. And if you can clean and redust the blade with some powder lubricate or yellow toner. And after that run 15 pages of yellow halftone prints to lubricate the belt.
