ic-313 2.2V wont activate...
  • methogod
    • Dec 2008
    • 922
    Was on 2.2v failed hard drive and memory. upgraded and replaced both. Now wont activate with clean install.
    EFI is little help.
    am i stuck rolling back to V 1.2? or can this be solved?
    Customer Service
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: ic-313 2.2V wont activate...
    Was it running win xp or 7 or 10?
    The windows license key sticker is not valid?
    I have a few fierys in my basement I converted into win 10 workstations but I remember using the key from another fiery to get one going running the real fiery system software.
    Xp is no longer supported and I don't think the win7 ones update either.
    You may need to roll back and see if it will let you patch it to 2.2.
    Yes it will take hours but if it works.....
    Also rumor has it that KMSPICO works too.
    • methogod
      • Dec 2008
      • 922
      only has a LTSC/LTSB windows 10 sticker.
      i know it was working when i got to it on V1.3 (i think).
      ill try that road if they don't write back tonight...
      take a long time, takes forever. 4 DVD to install, 2 more for 2.2 maybe more.
      my one dealer says 2.2 upgrade is not even available...
      not worried about activating windows 10, worried that EFI looks for the bios? or the windows 10 key.
      was also told to do it offline. so it will let you send them a code to activate.
      • Synaux
        • Mar 2012
        • 1224
        Shhhhh
        • methogod
          • Dec 2008
          • 922
          So what i have learned.....
          IS EFI are a pain to deal with...
          Think it needs a legit V2.0 update. Rolling back to 1.2v make sure everything works.
          • Synaux
            • Mar 2012
            • 1224
            • methogod
              • Dec 2008
              • 922
              EFI as a support system is not bad. Been chating with jorgan from efi back and forth. After no luck with 2.2v (never authorized LAC).
              Clean installed 1.2 and got an error, send error transcript to jorgan and he emailed me different ISO then i got from EFI and MKM.
              Still have issues sharing folders, but its printing.
              • Synaux
                • Mar 2012
                • 1224
                Really? I have never gotten anything useful from those guys. All my queries were essentially relegated to "not our problem" even though the issue was clearly with EFI (which I always managed to sort out without their assistance).
                Glad you got it hobbling along
