Need help with a 552 DF part number
  • SAR
    • Jul 2009
    • 203
    552 DF pic.jpg For some reason I can't find this part in the KM parts manual. If you raise the feeder up, it's the foam guide in the conveyance section (see arrow pointing at part). The foam has rotted out and it is falling apart. This is from a Bizhub 552 DF. I'm not sure if you can get by without this piece, but the tech having the issue said it is skewing without the foam guide.
    Thanks!
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Need help with a 552 DF part number
    Which feeder? Df-xxx
    • Albonline
      • Sep 2008
      • 1151
      Originally posted by SAR
      It's a DF-617.
      should be a 618 i think
      • Albonline
        • Sep 2008
        • 1151
        A0HT260400 Guide, i think that is what you want.
        • SAR
          • Jul 2009
          • 203
          Thanks Albonline, i'll give that a try. The DF came mounted on the 552 series from the factory, so the DF parts are in the copier parts manual. I tried to find a DF-618 manual on the KM site, but no luck.
          • Synthohol
            • 5849
            yeah, the feeder is included in the copier parts manual.
            also i wonder if that guide comes with the white piece?
            its shaped like a fat "T" but the manual only shows a strip.
            here is what albonline listed.
            • SAR
              • Jul 2009
              • 203
              552 DF seal.jpgJust got the part in and wanted to confirm that A0HT260400 Guide is the correct part. I guess KM was just too lazy to draw it correctly in the parts manual. Thanks again for the replies!
