BH-C-280/360 and BH-C-284e/364e series. Toner containing developer
  • Hansoon
    • Sep 2007
    • 3374
    Guys, anyone knows exactly which toner contains a little developer (carrier) too, and if, what amount?
    Is it only for K or also for the CMY toner and again, if, is this for C280/360/C284e/364e the same amount?
    Hans
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: BH-C-280/360 and BH-C-284e/364e series. Toner containing developer
    C280 and C360 only K. C284 and C364 has developer in all colors.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • copier tech
      • 8132
      Hans
      KM have a used the same identical toner for many years.
      For example I had an issue with C224e machines depleting cyan dev units & used the dev from some old used C552 image units I had laying around.
      After topping up the C224 dev units using the C552 developer quality was perfect.
        • 14522
        Hans
        acusso1234 is correct. Just black on c360 series and all colours on 4 and 4e series
        • femaster
          • May 2011
          • 1482
          Since the question has already been answered, I thought I'd share a random thought that ran through my head...
          I've never tried it, but I would think an easy way to confirm might might be to open the shutter on a toner bottle, insert a magnetized screwdriver into the toner and wiggle it around a bit and see if anything sticks to the screw driver when you pull it out. Maybe there isn't enough developer in it for this to even work, but since I haven't tried it, who knows.
          • Hansoon
            • Sep 2007
            • 3374
            Thanks Guys.
            That's what I did before but the result was not convincing enough. "Some" toner stuck to the magnet but not with the typical build-up of a "hairy" pattern one is seeing when having pure developer on your magnetic screwdriver. Also would it be nice to know the percentage of developer being added to the toner.
            Hans
            • REGSIS
              • May 2016
              • 434
              Don't know how much developer but enough to enough to recuperate half-empty brush on magnet roller.
              For example: Customer report (mainly) no cyan on top half of page.
              1. Clean drum unit/replace (if fully worn).
              2. Rotate dev unit manually (many is missing)
              3. Set TCR to -1 (mostly for cyan)
              Check after 5000 to 10000 pages - perfect brush and no toner buildup on charging grid.
              P.S. Take new yellow toner out of box and you will see black groups of developer in it.
              When you shake the bottle it will spread and not be visible any more.
              With compatible toner you cannot see black particles inside.
              • tulintron
                • Jul 2014
                • 669
                I place a small amount of toner on a sheet and pass the magnetized tool under the sheet. So I have my results.
