Konica Minolta C454
  • Kenny
    • Jun 2009
    • 538
    Konica Minolta C454
    Hi guys,
    We currently have a konica minolta c454 that will not take firmware, I have tried to to do the procedure but its boots up as normal.
    I have done the follwing:
    Tried various USB's
    formatted all USB'S to FAT32
    Blown out USB port
    re-wrote firmware off of USB's and re-downloaded
    we are currently trying to update the firmware to the special scan to email firmware as the machine is getting a forward TX error when scanning to email.
    Any suggestions will be appreciated
  • tsbservice
    Field tech
    • 8080
    Re: Konica Minolta C454
    Try to leave front door open.
    • copier tech
      • 8236
      Originally posted by Kenny
      Hi guys,
      Tried various USB's
      Blown out USB port
      What firmware version are you using, maybe it's not the correct version for your non 'e' C454.
      USB works best no larger than 2GB.
      And silly question, you are using the correct service USB slot?
      • Kenny
        • Jun 2009
        • 538
        thank you for the replies guys,
        I have managed to get it to boot to the screen with the fins and doesn't boot to the normal copy screen. I have been waiting for about 10 minutes for it to boot to the firmware screen, is this normal?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4788
          I've had it take 10+ mins. Just wait
          • Kenny
            • Jun 2009
            • 538
            still not booted to firmware screen, surley it doesnt take this long?
            • copier tech
              • 8236
              • emujo2
                • Mar 2017
                • 1579
                Are you seeing the black dot in the upper corner while it's trying to boot? E
                • emujo2
                  • Mar 2017
                  • 1579
                  Hi guys,
                  Tried various USB's
                  Blown out USB port
                  Did a little research (and this has been posted before) the non-e models must 1st be converted to e models before the special firmware can be applied..So if you are trying to put C454e into a C454 it won't work directly. E
                  • copier tech
                    • 8236
                    Thus my question asking what version he is trying to use.
                    • Walterj
                      KONICA MINOLTA
                      • Jun 2017
                      • 89
                      Hi guys,
                      Tried various USB's
                      Blown out USB port
                      I should first say which version of Fw you are trying to rewrite
                      With the acronym we will know what version it is and what changes it makes to your computer
                      When putting the USB before turning on the equipment, keep pressing the yellow reset button.
                      But it is important to know which version of Fw you are trying to rewrite as it may not be the model.
                      Check that the photosensor connector is properly connected to the MFPB.
