C250i does not boot...
Re: C250i does not boot...
Did you try use other similar ssd?
I found simillar memory, looks like in the KM
MyDigitalSSD First To Retail Phison E8 NVMe SSD | Tom's Hardware
PCIe M.2 NGFF SSD | Solid State Drives | MyDigitalSSD.com
but nowhere find to buy it.
I had 3 machines , 1 could format and reinstall in the machine, but 2 of 3 was not to able to format .Comment
this procedure mite helpComment
Word of warning this should only be carried out by an experienced engineer as this will completely wipe the machine including counters, serial numbers, storage settings and dipsw settings.
This procedure is a last resort from Konica and ideally shouldn't be banded about on an internet forumComment
I found other similiar ssd:
SSD Corsair SSD Force MP300 NVMe PCIe M.2
and
GOODRAM 256GB M.2 PCIe NVMe PX400
Phison E8 512GB M.2 NVMe PCIe
Read more: Phison E8 512GB M.2 NVMe PCIe SSD Preview | TweakTown
They had the same parameters :
PCIe GEN 3 x2 NVMe, 3D NAND flash
Attached FilesComment
The problem on there is your CPU board , had a couple of them here in South Africa especially with constant load shedding happening here. The device will not take any firmware while in this state.Comment
and
I'm not shure but I think the ones for KM are somehow prepared with a custom firmware or something else.Comment
