i series
  • POPEYE
    • Jul 2019
    • 10
    i series
    hello ,can anyone recommend the settings /services that are better disable when set up the i series ?like disable weekly timer,ip v6 ,sleep mode ,market place,screen saver ...to prevent problems like machine hang,white screen ,went offline ,failed to connect csrc,remote service .....everytime I setup new machine /service of iseries,waste alot of time to deal with these problems .thanks alot
  • KMFLT3CH
    • May 2017
    • 241
    Re: i series
    This will depend on the region and end user, but I always do the following on every I-series installs:
    Keep Classic copy screen as default:
    Admin mode > System Settings >
    Default Operation Mode Setting = CLASSIC STYLE
    Remove new style Basic copy screen button:
    Admin mode > System Settings > Main Menu Default (CLASSIC)
    Select row that says Basic style (#6?), Edit, Function Name = NOT SET
    Disable Marketplace & Screensaver, do this the AFTER machine has been networked:
    Admin mode > Network Settings > IWS Settings > Marketplace > Disable > OK
    Admin mode > System Settings > Reset settings > System auto reset > Screen saver function OFF
    Other more common settings like Sleep mode are turned Off (must allow in service mode first: System 1 > Sleep > Permit), low power set to 60min, Weekly Timer and Tracking functions both Off
    • Bix
      • Apr 2018
      • 1421
      Re: i series
      For the CSRC remember to disable WebDav, enable security protol. Also disable IP filtering if not needed
      • Woxner
        • Jul 2011
        • 850
        Re: i series
        for marketplace to be totally off set soft sw 172 to hex 01
        • rrrohan
          • Sep 2011
          • 1977
          Re: i series
          Originally posted by Bix
          For the CSRC remember to disable WebDav, enable security protocol. Also disable IP filtering if not needed
          i leave webdav on and CSRC works fine
          i originally disabled webdav to get remote panel working but then realised i just needed to select "individual settings" instead of leaving it on "synchronize" in the webdav config section of remote panel.
          • Max
            • Oct 2011
            • 561
            Re: i series
            Spent ages looking on how to set it to quick copy as default screen. Still couldn't find the correct option. Can any one point in the right direction please?
            Thank you.
            • KMFLT3CH
              • May 2017
              • 241
              Re: i series
              Thank you.
              Utility
              Customize
              Copier settings
              Quick copy screen
              OK
              • Max
                • Oct 2011
                • 561
                Re: i series
                Thank you.
                • copier tech
                  • 8172
                  Re: i series
                  Is it possible to change the Marketplace screen saver to a custom logo like we can with the boot screen?
                  • tsbservice
                    Field tech
                    • 8020
                    Re: i series
                    Really buggy app. If you have choice better remove this heavy bloatware for a good times.
                    • copier tech
                      • 8172
                      Re: i series
                      I agree its not really needed however i'd like to change the screensaver picture if possible, my marketing clients would like to see their own logo on the copier.
