konica 6500 c-2411
  • jorge_costa_cv
    • Dec 2011
    • 12
    konica 6500 c-2411
    hi .
    i have a konica 6500 and give an error c-2411.
    i changed the sensor on the dveloper still the same. i made an io test io-54-00 and 54-03 54-06 all in paramater stiil 00.
    in atachment teh print screen.
    can ani one help me??
    thanks118166810_2417919068507159_2187126785820386241_n.jpg118085820_309085670174567_6850644690280576928_n.jpg118254460_667486357485540_8476719055739101809_n.jpg
  • Synthohol
    Certified Konica Expert
    • 5463
    Re: konica 6500 c-2411
    Error
    C-2411,C-2412,C-2413,C-2414
    Root Cause
    C-2411, C-2412, C-2413 or C-2414 at power up or intermittently. Codes may be indicated when performing the drum adjustments.
    Workaround/Fix
    PROBABLE CAUSES:
    1. OPEN ICP15, 12V DC fuse (fuse type = ICP-S1.0) on the Printer Control Board (Printer Control Unit).
    Check the fuse on the PRCB and replace the board as necessary (p/n A03U R7B5 00).
    2. Failed TCR Sensor.
    Replace the Toner Density Sensor (p/n A03U M508 01) for the Developing Unit indicated by the failure code.
    3. Failed Process unit wiring harness connectors.
    Replace the Process Detection Wiring/1 (p/n A03U N110 01) and Process Detection Wiring/2 (p/n A03U N111 02).
    Note: Process Detection Wiring/2 is only listed in the bizhub PRO C6500/C5500 Parts Manual.
    • jorge_costa_cv
      • Dec 2011
      • 12
      Originally posted by Synthohol
      Error
      Root Cause
      Workaround/Fix
      PROBABLE CAUSES:
      hi i need the manual service to see where i can find (fuse type = ICP-S1.0) on the Printer Control Board (Printer Control Unit).
      i changed the toneer
      Toner Density Sensor but still same error
      • femaster
        • May 2011
        • 1417
        It's ICP15 according to Synthohol's. The service manual probably isn't going to be of any help as it most likely isn't going to point out the location of the fuse on the board. The fuse will almost certainly be a surface-mount fuse. They aren't meant to be replaced (though they can be if you know how), you are meant to just replace the whole board. You are going to have to take the time and look over the entire board until you find it. Once found, test it for continuity and go from there.
        • tulintron
          • Jul 2014
          • 651
          Another case is the processing unit. Check the closure of the unit. Bad closing generates error codes. There is a connector at the rear of the unit. Clean it
