Copy Program Button Missing on Bizhub C300i
  • captainrva
    • Oct 2014
    • 100
    I've got a Bizhub C300i and the Copy Program button is just missing from the copy screen. I'm looking everywhere to find an enable/disable but I'm having no luck.
  • copier tech
    • 8193
    Re: Copy Program Button Missing on Bizhub C300i
    [ATTACH=CONFIG]46639[/ATTACH]
    There were/still are a few bugs with the new i series.
    Most were resolved with a firmware update.
    • Synthohol
      Certified Konica Expert
      • 5868
      Blindly guessing here without checking the knowledge base, is the HDD enabled?
      • tsbservice
        Field tech
        • 8031
        There's a tool to edit panel buttons can't remember name right now. Also make sure it's on B5 latest FW as others mentioned it won't hurt for sure.
        Edit: panel customize tool I believe is the name
          • 30397
          Not sure if this works for your model
          think you'll have the option in there
          good luck
          • drowranger
            • Jul 2015
            • 122
            Like others said make sure you are running on function version 2 firmware.
            Please check [Administrator] > [SystemSettings]➔[Change Permission for Default Value]➔[ON]➔[OK] is set as well.
            • tsbservice
              Field tech
              • 8031
              Good call but I believe this is applied to Basic style and his problem is with Classic style copy screen.
