Marketplace Software Switch Settings
  • oliver88
    • 20
    Hello
    Does anyone know what the correct marketplace switch settings are for marketplace to work on a C300i?
    I have the latest firmware but it says firmware update needed, I think it's software switch related as my installer disables it by default because he hates it.
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: Marketplace Software Switch Settings
    just asking, why do you even want it?
    • oliver88
      • 20
      Because I want the connector apps it offers
      • copier tech
        • 8144
        Originally posted by oliver88
        Hello
        SW 172 HEX 01 hides marketplace so I would assume HEX 00 enables it?
        • oliver88
          • 20
          When I enable Hex 00, it reverts back to Hex 01 hmmm
          • tsbservice
            Field tech
            • 8010
            Do you have SM?
            • oliver88
              • 20
              Service Mode? Yes I do
                i think he talking about SERVICE MANUAL
                • oliver88
                  • 20
                  Yes, I have that too
                  • tsbservice
                    Field tech
                    • 8010
                    I forgot you're probably enduser. Yes I asked about service manual.
                    Edit:
                    Then study it. Your answer is in there. I can tell you needed Hex but it's better for you to learn a bit if you're going to modify sevice mode settings.
                    • oliver88
                      • 20
                      Yes, I have the service manual haha
                      The marketplace app works but gets stuck when I enter my login details, and the IWS installer on the PC says the firmware needs upgrading - but it is the latest firmware.
                      I think my tech disabled a SWW switch, but IDK which one
                        then READ IT
                        • tsbservice
                          Field tech
                          • 8010
                          I edited my last post as you confirmed that have manual. Just search for sw 172.
                          • oliver88
                            • 20
                            There is nothing in there under SW 172, I have searched the entire document
                            • copier tech
                              • 8144
                              Here ya go
                              SW 172 HEX 05.pdf
