Konica Minolta C654e Printing and copying issue
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Konica Minolta C654e Printing and copying issue
    Printing quality is not good and copy also, There is no error message (there is no error code)
    please see the attached photos
  • mayorg
    • Feb 2015
    • 53
    Re: Konica Minolta C654e Printing and copying issue
    Change the side door charger
      • 23008
      You might also have a broken second transfer roller mount. =^..^=
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        Agreed ......got to be a transfer issue. Any C2151 codes in service mode error history? Did you check that assembly? Pressure looks like it is not being not evenly applied. Something is not moving properly. Pressure is applied by the 2nd transfer pressure motor (M3) .
        Almost certainly 2nd transfer issue but I guess even the ITB unit itself in theory could also cause this. Let us know what the fix is.............
        • femaster
          • May 2011
          • 1504
          That definitely looks like a transfer problem. I agree with others in that it really looks like something is wrong with 2nd transfer. If there was a problem with the ITB causing that much image missing, you should see the "oil can" in service mode and probably have some P-Codes associated with incorrect readings from the density sensors under the belt.
          • greglogston
            • Jul 2018
            • 34
            I'd bet one side of your transfer roller is broken.
            • tulintron
              • Jul 2014
              • 668
              There is a black plastic piece on the left side, where the transfer belt is attached.
              Without it, the 2nd transfer unit does not close properly and defects like this can occur.
              I know this is commonplace, but it can help.
              As friend Phil B says: "The Dentist"
              • musthafavi
                • Aug 2017
                • 76
                Yes your are right, there was problem with second transfer roller unit
                Second Transfer roller unit has been fixed properly and now its working fine
                • musthafavi
                  • Aug 2017
                  • 76
                  Right side plastic piece was broken, i fix it and now its working fine
