C300i Consumables Stopped Displaying Life
  • oliver88
    • 20
    I fixed it by reading the service manual ha!
  • GIUBOSS
    • 1437
    Re: C300i Consumables Stopped Displaying Life
    Welcome you are a tech or paper consumer 😉
    • tsbservice
      Field tech
      • 8081
      What's the point of this thread?
        a newbie tech 'cording to his profile
        0-2 years
          he has posted other problems... I believe I told him to GET n READ the f'in manual
          glad to see he CAN take advise
          littl info in his profile tho...
          no training
          no hated brand
          no 1st trained on
          • oliver88
            • 20
            I asked originally, then edited it as I fixed it myself.
            I couldn't see an option to delete the thread.
            • emujo2
              • Mar 2017
              • 1579
              Well you can pat yourself on the back or maybe you can post what the issue was and how you solved it..Being a contributor means more that just dropping a dollar in the bucket. E
              • tsbservice
                Field tech
                • 8081
                He was missing the subject in another thread and copier tech gave him solution straight from SM. So hopefully he's now really reading it. Other than that I'm with you on this - 100% .
                • Synthohol
                  Certified Konica Expert
                  • 5922
                  just in case someone was looking for the solution, it is to set bit switch 227 to hex 00 hit fix.
                  • oliver88
                    • 20
                    It was software SW 227: it had for some reason been set ot set itself to 80, setting it back to 00 fixed it. Maybe the firmware update was the cause.
                    I edited my post because I could not see an option to delete and I since read the manual and sorted it.
