Konica Minolta C MF335 Touch Panel stopped working
  • eli
    Not a technician
    • Oct 2014
    • 40
    Hello All,
    The touch screen panel stopped responding to touches. What are some of the possible fixes, besides replacing the screen? It works somewhat at the bottom in certain areas but 95% of it doesn't work.
    edit: Correct model is bizhub C3350
  • Synthohol
    Certified Konica Expert
    • 5906
    Re: Konica Minolta C MF335 Touch Panel stopped working
    what model? mf335 is not a US model#
    typo?
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Originally posted by eli
      Hello All,
      Would love to help but................Never heard of that model. Not coming up in Google search either. Please verify the model.
      • eli
        Not a technician
        • Oct 2014
        • 40
        Here you go, says Model Name: C MF335-1
        • eli
          Not a technician
          • Oct 2014
          • 40
          I think it is konica minolta C3550
            Hello All,
            1) what happened before the screen went dark?
            2) does that have a brightness dial?
            3) has it been moved to/from it's present location? ( many times they grab that portion of the top and use it as a handle to pull/push the unit into place )
            4) can you see any message / function screen at all? any codes?
            5) Is the machine on a cheep surge protector?
            6) is the machine receiving proper operating power from the wall?
            7) Any RED lights showing?
            8) can you print to it? ** If using that function**
            9) can you hear motors/scanner move when powered on?
            10) Scanner lamp moving and lit?
            Soooo many questions .. so little info given.
            • blazebusiness
              • 1257
              [ATTACH=CONFIG]46679[/ATTACH]
              That's not the model.....that is apparantly associated with type of direct print network printing software:
              Never heard of it but I Found this on google-------
              Direct Print C MF385-1_C MF335-1_BW MF475-1_BW MF405-1 is developed by KONICA MINOLTA BUSINESS TECHNOLOGIES, INC..
              • eli
                Not a technician
                • Oct 2014
                • 40
                My apologies, i didnt explain myself. The screen works perfectly. The touch screen is not responding to any touches, so cant do any scanning, etc.
                See above, screen itself works perfectly.
                It has been moved but since hte time it was working perfectly until now, it hasn't been moved.
                no codes, no errors
                Not sure, will check.
                6) is the machine proper operating power from the wall?
                Yes
                Nope
                Everything works, just cant touch anything on the screen.
                works perfect, makes copies, etc
                Yes
                • eli
                  Not a technician
                  • Oct 2014
                  • 40
                  Originally posted by blazebusiness
                  That's not the model.....that is apparantly associated with direct print printing software:
                  It is bizhub C3350, just confirmed it.
                  • blazebusiness
                    • 1257
                    Unfortunately that model has had a history of screen failures. You may have no choice but to replace it.
                    There is a bulletin saying it could be bad expansion memory also in addition to the panel.
                    • eli
                      Not a technician
                      • Oct 2014
                      • 40
                      Yep, just found the thread after i found the right model number. Where is the expansion memory module? I apologize about a dumb question, not a tech. Just trying to see if i can get this machine working
                      • blazebusiness
                        • 1257
                        Not a tech.and probably didn't even buy the service manual....I think you should be afraid to even try it......
                        But since you want to know------It's probably on the MFP board I'd bet. You could take off the back cover and look for memory (maybe like dimms) to unplug or reseat. Don't mess with anything else though like the ssd board or eeprom. Memory should be pretty easy for you to spot and identify. If it doesn't look like memory leave it be.
                        The only memory board that comes up in the part manual I have looks like this:
                        Konica Minolta (S)Memory Board(WW) A3GNR71033 A3GNR71044
                        • femaster
                          • May 2011
                          • 1526
                          You guys might want to be careful at that link. It looks like they could have possibly had their website compromised...
                          • blazebusiness
                            • 1257
                            [ATTACH=CONFIG]46683[/ATTACH]
                            Been posting here since 2010 and you can trust my posted links. I am always very careful and would never in my recommendations post a bad link. Have gone to that website many times over the last year and no issues. Get a new antivirus program that can discern between threats and non threats. I thought eset was pretty good but they failed you at least on incorrectly flagging this one website.
                            I researched this further to be absolutely certain , if you go to the eset's own forum many many frustrated users of the eset software are reporting false positives with that exact "supposed" trojan....nothing personal but when that threat appeared on your computer , for curiosity alone maybe you should have researched it yourself first before trashing my link.
                            Again, nothing personal. I have enjoyed many of your posts in the past. Just don't want anyone to get the false impression that they can't trust my links or recommendations.
                            • femaster
                              • May 2011
                              • 1526
                              I never said you were purposely trying to lead anybody to an infected website, and I'm sure you have been going there for years without a problem. As can be seen in the image, it indicates that this particular infection was first seen 3 days ago, so if the site were infected, it happened very recently.
                              I think your insistence that I get a better antivirus is very misplaced here. Eset is one of the top antivirus companies on the market, and I've never had an issue with them leading me astray. Like you with that website, I've never had a problem with Eset offering up false warnings on website infections before. Not saying it's not possible, as anything is possible, but so far their track record has been impeccable for me, so I think I'll be sticking with it.
                              Thank you for taking the time to look into that trojan report. Generally I do research when I come across things like that, however, I was up much later that I should have been at that point, and I needed to get to bed. Like I said before, I have never been lead astray, so I just went with it. There was no intention on giving the impression that people can't (or shouldn't) trust your link(s). If that were my intention, I'm sure that I wouldn't have chose now to start flagging them. All I was doing was stating that people who were to follow it should "be careful" as there was a potential issue.
                              I've since had the time to in fact do some extra checking, and I've run that site through a number of online scanners, and each has stated that it came back clean. My apologies if my previous post offended you in any way. I was just trying to look out for others here, as I would hope the others would do for the rest of us.
                              VirusTotal
