Konica Minolta 654e - E3-01
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta 654e - E3-01
    Getting E3-01 in Konica Minolta 654e (B&W).
    Kindly advise if it needs to upgrade the firmware.
    Thanks and Regards,
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: Konica Minolta 654e - E3-01
    Updating F/W is always a good place to start with those odd codes. Also check if any bulletins specific for that code.
    Check that correct memory is installed or replace memory
    Do a memory test in service mode.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Thanks and Regards,
      With the most recent firmware installed we have almost completely eliminated the E3-01 codes on our 4 series machines. Now (but very infrequently) occasionally a print job still throws the code.
      • femaster
        • May 2011
        • 1514
        As other have said, firmware needs to be updated. In the early days, those errors would show up constantly in the logs. There was a firmware update released that specifically addressed this error. There has been a few more updates since that time, so if you can get your hands on the latest, you will be all set.
