Bizhub C5501 J-3205 with no finisher
  • gabitzzup
    • May 2012
    • 8
    [Jamming] Bizhub C5501 J-3205 with no finisher
    Hi, can anyone help me ?
    I have a bizhub C5501 and the jamming error is just when duplexing.
    I so that the A03U 8926 00 PAPER EXIT ROLLER /B is moving when is printing one side, but is not moving when duplexing and that is the reason that is throwing that jamming code ( the m54 motor is spining)
    If i'm duplexing and i remove the paper from the exit with my hand the printer is working ok.
    is there a dipsw switch that can be set may be ?
    Any suggestion will be appreciated.
    Thank You !
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C5501 J-3205 with no finisher
    I have found that on the some of the production machines it needs the finisher to pull the paper out of the exit section.
    Whatever
    • gabitzzup
      • May 2012
      • 8
      ok, it is possible, but why on single side it spits the paper out and when duplexing is not ?!?
      • allan
        RTFM!!
        • 5462
        Different path different curvature to the paper?
        Where is the finisher?
        Whatever
        • gabitzzup
          • May 2012
          • 8
          just bought without finisher .
          • allan
            RTFM!!
            • 5462
            You are going to have to get creative in getting the paper out of the machine.
            Did it come with an output tray?
            Whatever
            • gabitzzup
              • May 2012
              • 8
              No.
              • Synthohol
                Certified Konica Expert
                • 5892
                oh the memories...
                check the one way gear in red circle, clean the gear with alcohol and scuff the shaft left to right where the gear rides (also in a red circle)
                the needle bearings slip and dont keep pressure on the foam roller to completely push out the paper.
                • gabitzzup
                  • May 2012
                  • 8
                  Thank you, i will try this, but is working just fine when not duplexing... when printing in duplex the foam roller is lowerd down and the paper just stay half outside and pop the jamming code.
                  • Synthohol
                    • 5892
                    once the side cover is off, watch the operation of the solid roller, that is the one that is supposed to turn, it drives the foam one.
                    forgot to mention, there is an annoying bracket and gear to remove to get to the clutch gear. dont get discouraged.
