Bizhub C552 background
  • potro_salvaje
    • Sep 2010
    • 23
    Good day everyone. I have a Bizhub C552 that has a background at the beginning of the sheet, drums/devs has already been reviewed, transfer unit has also been reviewed and it does not seem to have anything unusual, any suggestion would be very helpful, i send a reference image.
  • GIUBOSS
    • 1436
    Re: Bizhub C552 background
    If drum and development units ok, it could be the MFP board.
    • mayorg
      • Feb 2015
      • 53
      Clean the second transfer
      • copier tech
        • 8169
        [ATTACH=CONFIG]46843[/ATTACH]
        What does this mean "drums/devs has already been reviewed, transfer unit has also been reviewed"
        So you replaced ALL image units & the transfer unit?
        • tsbservice
          Field tech
          • 8020
          Review, I feel in this case means to look carefully at parts
            visually doesn't mean they were checked mechanically.
            IHMO visual inspections are good to only a certain point... then the real troubleshooting MUST take over.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              Are those image units past life?
              Did you check the TCR values in service mode? Should be around 7 or 8.
              A visual inspection of a drum/dv unit will normally not reveal much......
              • tsbservice
                Field tech
                • 8020
                Completely agree Phil.
                  +1
