Consumable counter is incorrect
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Hi Gents,
    I have a few C759's that are reflecting incorrect life counters.
    We replaced imaging units and the counter did not reset to 100%.
    Is there a dipsw or something that I am missing here, has anybody had this issue before.
  • tsbservice
    Field tech
    • 8013
    Re: Consumable counter is incorrect
    Originally posted by byronf
    Hi Gents,
    Sounds like a firmware anomaly. Try latest and greatest.
    • byronf
      Senior Member
      • Sep 2017
      • 109
      Hi I have updated FW G00-W5 still have no luck with the state of consumable counter.
      Eariler this year I had another machine do this but I over looked it as we were heading for lock down. Now this machine at another client has the same issue. There is no copy quality issue machine is running 100%. My thing is I just need to correct this as our clients think the unit was not replaced.
      • Synthohol
        Certified Konica Expert
        • 5824
        if indeed new units were installed and the counter did not reset you can warranty the IUs 100%
        • copier tech
          • 8144
          Hi Gents,
          Were these genuine Konica Minolta image units or compatible/rebranded types?
          You can hide that consumables counter tab using SW227 that way you client can't see the unit life maybe a work around for you.
          • tsbservice
            Field tech
            • 8013
            We're struggling with KM support also... and not due to lack of knowledge and using compatible parts. KMBS have dealer support programs not known in elsewhere.
            • byronf
              Senior Member
              • Sep 2017
              • 109
              These units are genuine and brand new. At first I assumed ENGINE DIPSW 3 (Disable New Release) was activated, I have confirmed that this is disabled.
              We now have another machine that did the same.
              Where can I get special dipsw list from for this model.
              • Synthohol
                • 5824
                its in the service manual no?
                  per forum rules ALL manual requests are to be made in this forum: https://www.copytechnet.com/forums/s...nual-requests/
                  • allan
                    RTFM!!
                    • 5462
                    To get closer to some kind of answer check the chip fuses.
                    Blown or not?
                    If they are blown they could have been faulty or blown before.
                    If not the machine is not doing its job of detecting the new articles.
                    Whatever
