4700p jamming
  • tech51
    • 846
    4700p jamming
  • qbert69
    • Mar 2013
    • 1152
    Re: 4700p jamming
    Perhaps a frimwar update/refresh might resolve this issue?![emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Synthohol
      Certified Konica Expert
      • 5823
      Re: 4700p jamming
      Page at fuser nip before fuser reached
      acceptable operating temperature. Page
      arrived at fuser earlier than expected, so it
      was probably staged.
      could be firmware or maybe try bumping up the temp by +5c
      does that fuser have "envelope mode"? maybe its set there in error?
        • 23007
        Re: 4700p jamming
        Short term, you might disable sleep mode. Until you find a better solution. =^..^=
        • M94
          • Jul 2020
          • 158
          Re: 4700p jamming
          Put better than I would have said it, but yeah if it's always the first print after idle that makes me think the fuser is not performing properly from a cold start. Blackcat had it right though, disabling sleep would probably 'solve' it for now.
          Edit> If the fuser has already been replaced for the same reason maybe it's not getting enough juice to heat quickly?
          • antone
            • Oct 2014
            • 344
            Re: 4700p jamming
            wash rollers good.
            Sent from my SM-N950U using Tapatalk
              • 23007
              Re: 4700p jamming
              We've got a Kyocera printer of approximately the same vintage doing the same thing.
              Except on the Kyocera there are multiple bulletins and multiple updates. They changed the drive gears on the fuser drive pack, changes to engine firmware, and multiple changes to the fuser (mainly the teflon pressure pad bunches up at the the exit side). There are currently 6 revisions on the fuser, maybe more in the works.
              I think I'd check the Konica Bulletins for something like this.
              • albemero
                • Apr 2019
                • 37
                Re: 4700p jamming
                I would say inspect the fuser .. perhaps you ll find a broken guide or something like this
                a broken guide or somethinga broken guide or somethinga broken guide or something
                • tsbservice
                  Field tech
                  • 8008
                  Re: 4700p jamming
                  Fuser was replaced.
                  • KMFLT3CH
                    • May 2017
                    • 230
                    Re: 4700p jamming
                    Did you ever find a fix for your issue? I am having the exact same problem, same model.
                    • tech51
                      • 846
                      Re: 4700p jamming
