C2557 on a new C3300i
    • 8101
    [Error Code] C2557 on a new C3300i
  • rrrohan
    • Sep 2011
    • 1977
    Re: C2557 on a new C3300i
    there are bulletins for this on the C3320i
    if you dont have access ill link it to you in about 12 hours when in office
      • 8101
        Speaking of tech bulletins, can I purchase those from you for Kyocera models?
          • 8101
          Yes sure, but you might want to post any issues you have in the Kyocera forum by starting a new thread.
          • allan
            RTFM!!
            • 5459
            Does the TCR value change if you manually add toner?
            0.6% is almost completely detoned.
            Would then expect it to be a factory error somewhere.
            Bad part or not connected.
            Whatever
            • tsbservice
              Field tech
              • 7911
              Warrant - this is faulty K IU.
              • Max
                • Oct 2011
                • 546
                I think this is what you are looking for.
                  • 8101
                  Thanks for the info but this pic is too small to read, could you possibly PM me this bulletin please?
                    • 8101
                    I can't see how to manually add toner on this model, it used to be in CE mode > Image Processing Adjustment > Manual Toner Add. However this option is not there on this iseries?
                    • splblazer91
                      • Jul 2014
                      • 204
                      You have to upgrade to the latest FW and then you will have the option. They call it high speed agitation in the tech pub but its manual toner add in service mode. Do it twice and if that doesnt fix it then you will have to replace the IU.
                      • allan
                        RTFM!!
                        • 5459
                        Sorry by manual i mean the old fashioned way to add a bit of toner in the tank.
                        If the value goes up it shown life at the TCR sensor.
                        I would try to recover the developer and then try to find the cause for it not to get toner.
                        If all seems well it should dwell around 6.5%. If not i will reset the tank with an eyeballed density.
                        How dense is a half tone at 255? Should be very faint.
                        Then if you can claim the unit....
                        Whatever
                          • 8101
                          Thanks this will explain it.
                          I tried to load the G00-B5 firmware but the machine just hung on the progress bar screen & didnt install.
                          • antone
                            • Oct 2014
                            • 344
                            chk level history 6 7 volts
                            Sent from my SM-N950U using Tapatalk
                            • REGSIS
                              • May 2016
                              • 434
                              Bad IU. Warranty!
                              A year passed since initial models and still this issue is not sorted out.
                              Drums doesn't look like KM (different colour).
                              Is this model rebranded?
