Hey mates :-)
I have a C558, which i have tried to FW upd. It failed at MFP with N.G. I have tried several versions, all with same outcome. Tried to upd. MFP only. Tried with the HDD disconnected.
And after the first failed attempt, it cant start as normal, it just says "This is invalid external memory" But there is no external mem attached, and i am not holding down the stop button.
Could a MFP reset tool be a solution? But i cant find one for C558. At our partner portal. Or KM ftp server.
Which machine type is the C558? 9 - 9 is choosen by default at firmware upd.
Thanks in advance :-)
