C364e scans
  • emujo2
    • Mar 2017
    • 1579
    [Misc] C364e scans
    Getting this from all scans..copies made from glass are good, only when ADF is used..Affects anything 8 x 11 LT or Ledger. Single pass ADF. Thinking the scan bed may have been damaged but really don't want to swap if at all possible. I have had 2 techs looking at this and they can't figure it out. 8570.jpg
  • progoffice
    • Nov 2008
    • 336
    Re: C364e scans
    Maybe you can put a Dual Scan doc feed on it (if you have one) just to see if the second side does it as well. The image is processed differently (CIS), so it might be worth a try to help pinpoint the only scenarios where this is occurring.
    • tsbservice
      Field tech
      • 8020
      Re: C364e scans
      +1 to this test.
        • 23009
        Re: C364e scans
        Were I to make a guess, and I've seen this somewhere before, light source #1 or light source #2/#3 tips as it slides into position under the slit glass. The possible reasons can be:
        * a dry scanner rail
        * a damaged or missing slide (plastic disk that acts as a sliding surface between light source and the rail)
        * a damaged pulley or pulley bearing
        * a damaged rail (some scanners have a chromed metal strip adhered to the scanner frame, and that strip can come un-stuck)
        * or you might have some foreign object bumping one of the mirror assemblies, like a wire harness or light shield
        Were it me, I'd take off the glass and turn the drive hub towards the slit glass position slowly. Since it doesn't affect prints off the glass, one of the light sources must shift or be bumped in the last few millimeters of travel.
        What if somebody installed a cover screw that was just a little bit too long in the end cover of the scanner? LOL.
        • Synaux
          • Mar 2012
          • 1224
          Re: C364e scans
          That last one... lol I could see something like that potentially wasting a LOT of time!
          Anyways, much of the same stuff, I have seen something similar when a mirror was not seated correctly (looked like it was but little jiggle it snapped into place).
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Re: C364e scans
            This
            and seen distorted scanner frame do this too, not necessariliy visible, the bottom plate the ccd sits on can distort.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              Re: C364e scans
              Originally posted by emujo2
              Getting this from all scans..copies made from glass are good, only when ADF is used..Affects anything 8 x 11 LT or Ledger. Single pass ADF. Thinking the scan bed may have been damaged but really don't want to swap if at all possible. I have had 2 techs looking at this and they can't figure it out. [ATTACH=CONFIG]46943[/ATTACH]
              Saw something similar way back with something blocking the light path but only when scanner was near home position. Turned out to be small piece of hanging fuzzlike debris underneath slit glass area.
              • tulintron
                • Jul 2014
                • 668
                Re: C364e scans
                Emujo, I've come across this a few times. Some very tired users rest on the machine, causing the Scanner base to tilt on the left front side, the only part where the base is not attached.Remove the covers, just loosen the screws and reposition the base.
                I believe it will be enough.
                • emujo2
                  • Mar 2017
                  • 1579
                  Re: C364e scans
                  Thanks, wish I had a spare dual scan for a C364e sitting around..E
