C224 Colour Print Problem (Shfting, Blurry Images). Also show P-21 error.
  • jamaicapepe
    • Sep 2017
    • 15
    Hello,
    I am including photos of a test page so you can understand easily.
    We have changed belt about a month ago. Also tried PH Skew and after Initialise and Image Stabilisation
    as proposed by the service manual but still no luck.
    Any ideas?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Re: C224 Colour Print Problem (Shfting, Blurry Images). Also show P-21 error.
    Originally posted by jamaicapepe
    Hello,
    Any ideas?
    [ATTACH=CONFIG]46948[/ATTACH][ATTACH=CONFIG]46949[/ATTACH]
    You need to get rid of P-21 so you can do gradation adj
    I would start with making sure the IDC sensors are clean & shutter opening ok.
    Possible it needs at least the Magenta drum.
    Swap the magenta drum unit with the Cyan drum unit and see if the Magenta over bleed turns to cyan. Then you will know original magenta drum is bad.
    • copier tech
      • 8165
      Hello,
      Any ideas?
      Clean the patch sensors & then run 'initialise + stabilize in CE mode.
      โ€‹
      • tsbservice
        Field tech
        • 8019
        Likely patch sensors or try crash stop A3 paper partly in the fuser and see where image is mis-registering.
        • jamaicapepe
          • Sep 2017
          • 15
          I can't seem to find the IDC sensors. As i see in the manual they should be under the 2nd transfer roller or am i wrong?
          • jamaicapepe
            • Sep 2017
            • 15
            Hi! What do you mean by "patch sensors"? I can't find anywhere in service manual. Also CE mode = Service mode?
            • tsbservice
              Field tech
              • 8019
              They are under TBU(right side).
              Patch sensors = IDC sensors
              Last edited by tsbservice; 10-03-2020, 06:22 PM. Reason: Uggh, right side not rear
              • jamaicapepe
                • Sep 2017
                • 15
                Cleaning the IDC Sensors cleared the error and fixed the colors! So... a huge thanx to everyone!
                Now there is another problem. I did a gradation test and it doesn't print black on the right side
                of the page as you can see in the image i upload now.
                As i said i have changed transfer belt recently and also changed the black drum.
                Does anybody know what else should we check???
                • copier tech
                  • 8165
                  [ATTACH=CONFIG]46950[/ATTACH]
                  Clean the printhead with the cleaning tool inside the front door & clean the black charge wire & grid.
                  โ€‹
                  • jamaicapepe
                    • Sep 2017
                    • 15
                    I will try on Monday and report back with the results. Once again thanx to everyone who helped!
