Bizhub C558 J9901
    • 8188
    [Jamming] Bizhub C558 J9901
    Hi all,
    But stuck fighting this one, intermittent J9901 from all 4 trays. Seems to be OK on landscape but jams very frequently if paper is load portrait.
    Machine has over a million on the total counter & replaced all the feed rollers no change.
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub C558 J9901
    I'm betting it's vertical rollers worn so bad it can't grab the paper tight enough to feed reliably. Of course, by now I would think you'd know to say SEF or LEF vs. the very confusing landscape/portrait vernacular which can be interpreted either way for each one. Just some good-natured ribbing!
    If in fact, LEF feeds better than SEF, I stand by my first statement.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Hi all,
      check that the registration actuator at the registration roller is *consistantly* moving freely and returning back quickly and not lazily.
      remove and clean if required.
        • 8188
        ​I think portrait/landscape is a United Kingdom term, I worked for Canon & that is how they describe the paper orientation or they use A4/A4R.
        ​I've ordered the reg sensor, actuator & clutch.
        • tsbservice
          Field tech
          • 8029
          I think most universal would come SEF/LEF. It eliminates different paper standard/sizes plus landscape/portrait is more common in print drivers than in copier documents I know of.
          Btw, good luck with error solving.
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5858
            22 years ago when I started this career the terminology was letter or letter r
            Apparently this was too much for people so the long edge\short edge first started to take the guesswork out of the letter r for rotated.
            Next it will be called the 11" or 8.5" side because people can't adapt to shit.
            216x279 for the folks across the great pond lol because A4 is taller and thinner than our paper.
            • srvctec
              • Oct 2009
              • 827
              Wait, "Letter R" meant rotated? Back when I started in 1988 Letter R meant Letter Reduction, meaning the lead edge had to be 8 1/2" because when you reduced with analog machines, the lens moving and scanner speed combined to make the reduction only fit if the lead edge was narrow (8 1/2").
              In any case, I think LEF and SEF are the easiest and most universal, leaving no room for confusion.
              Hope you get the issue resolved, @copier tech!
                • 8188
                Yes 'R' does indeed stand for reduction as I say Canon still use this term.
                Regarding this issue I replaced the registration parts in the pic.
                Looking at the reg arm its worn down I suspect this was the cause.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  wow this thread went off on a wild tangent.
                  I like to use the term short edge feed and long edge feed - but people look at me blankly when I use these terms and end up having to revert to using the terms landscape and portrait also. We arent dealing with paintings here - SEF and LEF should be it.
                    • 8188
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      Sadly, half the techs I work with don't know what I'm talking about most of the time anyway
