c3850fs
  • adecanmin
    • Oct 2010
    • 321
    c3850fs
    Gentlemen.
    I have a theory of operation question. I looked in the service manual could not find the answer. How are the 24 volts initialized? Is the signal generated from the mfpb to turn on the 24 volts in the power supply or does the prcb perform the action?
  • allan
    RTFM!!
    • 5462
    Re: c3850fs
    Are you repairing a power supply?
    Whatever
    • adecanmin
      • Oct 2010
      • 321
      Re: c3850fs
      Its a shop as well as a parts machine. It was working somewhat. I was reseating one of the ribbon cables to the scanner because I was getting a getting a scanner service code, it came loose and touched the mfpb board. Of course I had the machine powered on. It went dead. I have 5 volts but no 24. Not a big deal if I can't get to power up but I would like to know which board I took out. I'm thinking mfpb.
      • allan
        RTFM!!
        • 5462
        Re: c3850fs
        The power switch is connected to DCPS then it looks like its gives 5V power to the MFPB thru pins 4 5 and 6 on CN5.
        CN3 of the DCPS pin is Input Power Monitor and on pin 4 Sleep Remove that goes to CN2 on the PRCB.
        CN4 on the PRCB goes to CN16 on the MFPB taking with it Sleep Remove but not Input Power Monitor.
        3.3V gets converted on the MFPB and supplied to the PRCB and itself.
        Check for 3.3V if its not there the MFPB could be dead.
        The Sub Power Switch goes from the control panel to the MFPB.
        My guess would be the PRCB controls the 24V but if 3.3V does not get supplied to the PRCB it would no work anyway. Think one of the chips would be shorting that out.
        AC Power Off is monitored by the MFPB.
        Sorry for the edit on the vodka and bored.
        Check for 3.3V on the MFPB.
        Whatever
        • adecanmin
          • Oct 2010
          • 321
          Re: c3850fs
          Thanks! Have you had to replace any scanners on these machines? Unfortunately it is an assembly and an expensive one. I had one that was giving the scanner lock code intermittently and the other one had a bad ribbon cable causing a code . I was able to take the ribbon cable off the one that was giving the scanner code so I was able to avoid having to replace two instead of just one. It is cheaper to buy a used machine with a good scanner then to replace it to tune of $860.
          • allan
            RTFM!!
            • 5462
            Re: c3850fs
            Would that ribbon cable happen to be CN103 and not CN102 on the MFPB?
            You could be lucky and just lightly roasted an ICP.
            Whatever
            • adecanmin
              • Oct 2010
              • 321
              Re: c3850fs
              cn102
              • allan
                RTFM!!
                • 5462
                Re: c3850fs
                There are no 3.3V pins on CN102 but CN103 does have.
                Ok check for 3.3V. Put your tester to peak hold and have the probes connected at power up.
                And check ICP's and other fuses.
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  Re: c3850fs
                  I have solder repaired the ribbon cables before to avoid replacing them.
                  find the crack in the ribbon or where its worn thru and scrape the insulation off with a blade and flow solder from the one end to the other.
                  Whatever
                  • adecanmin
                    • Oct 2010
                    • 321
                    Re: c3850fs
                    Ok, I've read about the ICPs. I don't know where they are located on the circuit board. I've only found two fuses both on the power supply. Thank you for your help.
                    • adecanmin
                      • Oct 2010
                      • 321
                      Re: c3850fs
                      I'll try that next time.
                      • adecanmin
                        • Oct 2010
                        • 321
                        Re: c3850fs
                        I found the icp list in the manual
                        • femaster
                          • May 2011
                          • 1519
                          Re: c3850fs
                          The ICPs are tiny little surface mount components on the board. They are about the size a surface mount resistor or small capacitor. Look for the silkscreen label on the board as ICP# (ICP and then it's number). Sometimes a bit tricky to find, but just look real close and you'll eventually find them all.
                          • adecanmin
                            • Oct 2010
                            • 321
                            Re: c3850fs
                            Thanks. They are small
