Konica Minolta C308 - Quality issue
  • Kenny
    • Jun 2009
    • 530
    [CQ] Konica Minolta C308 - Quality issue
    Hi guys,
    we currently have a Konica Minolta C308 at a customers that is doing the below:
    I have pulled out all the developing units and the only thing that was out of place was the cyan developing unit which has turned black. The machine is on the latest firmware, has about 150k on the machine, i am possibly suspecting replacing the HV board, but before i attend does anyone else have any suggestions?
  • woo
    • Apr 2017
    • 3
    Re: Konica Minolta C308 - Quality issue
    Hi Kenny, check lasers(aka ph unit)
    • Bix
      • Apr 2018
      • 1421
      Toner OEM?
      • Kenny
        • Jun 2009
        • 530
        Originally posted by Bix
        Toner OEM?
        Yes the toner is Genuine
        • Kenny
          • Jun 2009
          • 530
          sorry i forgot to mention the TCR levels are also at:
          TCR-C - 0.00
          TCR-M - 6.40
          TCR-Y - 6.32
          TCR-K - 0.00
          i did try to bring these levels back up but they wont budge, i have checked the plate above the developing units duct is moving as it should.
          • robinsonad86
            • Aug 2014
            • 67
            Pop the white collars off the front of the toner hopper suspect c and k may be blocked which would explain low TCR values and cyan dev being drained of colour
            • tulintron
              • Jul 2014
              • 668
              TCR-C - 0.00
              TCR-M - 6.40
              TCR-Y - 6.32
              TCR-K - 0.00
              If there was any technical intervention on the drums, I recommend checking the fit of the load rollers. They can consume all the toner if it is bad contact.
              https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
              • Gift
                • Mar 2011
                • 2459
                Leeds, cool city, I stayed there in a very funny/awkward hotel near the train station once^^
                Seems the cyan DV unit has been drained due to a faulty drum unit or the HV PWB has gone bad.
                When the C308 series was new we had a few cases with DV drainage as well -almost no clicks on the counter and the waste bottle was
                heavy-weighted because the dev went in there.
                • REGSIS
                  • May 2016
                  • 435
                  Hi guys,
                  CYAN, MAGENTA, YELLOW, BLACK, HALFTONES.[ATTACH=CONFIG]47059[/ATTACH]
                  [ATTACH=CONFIG]47060[/ATTACH]
                  HV board is the main suspect. It will suck all the toner from DV unit but not developer. DEV-C unit is left only with developer which is of black colour. It s not turned black, only cyan toner is gone.
                  • Terna247
                    • Jan 2019
                    • 64
                    The corona blade and the chargers saved me timelessly outta that situation.
                    Sent from my Infinix X606C using Tapatalk
                    • femaster
                      • May 2011
                      • 1514
                      I'm not completely sure I understand what you are saying here, but regardless, the C308 doesn't have coronas, it has charge rollers in the drums.
                        Charge rollers can be cleaned w/ NuFinish car polish
                        PM me for procedure
