Bizhub c224 - scanner issue
  • tsbservice
    Field tech
    • 8019
    #16
    Re: Bizhub c224 - scanner issue
    For sure when floor is perfectly horizontal otherwise you haven't good starting point to level. Tell us you level the copier glass on every new install place of office machine.
      • 23008
      #17
      There aren't many level floors out there, and there are very few MFPs with the leveling feet screwed down. Measuring to the floor seems to work for me. =^..^=
      • Synthohol
        Certified Konica Expert
        • 5841
        #18
        i would check/adjust the level of the main body first so the level of the scanner has a reference.
        besides, i just wedge a knee up under the scanner and push up while making a copy to see if in fact the scan bed is bent down.
        when i did production machines i could use the level every day, MFPs not so much unless an issue warrants it
