Bizhub C250 black edge on top of paper
  • HasseM
    • Jun 2020
    • 5
    Can someone tell me what can be causing the top side of all prints to have a black line?
    see:
    It seems to be getting worse over time. Probably I either need to clean something or adjust something....
    Thanks you very much for taking the time to help me.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Re: Bizhub C250 black edge on top of paper
    see:
    [ATTACH=CONFIG]47099[/ATTACH]
    Looks like transfer belt or black image unit.
    If you run paper the other direction line should not show since it's on the edge.
    • HasseM
      • Jun 2020
      • 5
      Transfer belt and imaging unit have been replaced not too many prints ago. So, is that a matter of replacing or cleaning?
      How to "run paper the other direction" ?
      • Toxic
        • 698
        It does not matter when parts are replaced, it could be damaged.
        Is it same on copy and print jobs?
        Did you visually check drum and belt surface?
        • HasseM
          • Jun 2020
          • 5
          I'm not expecting it to to be damaged because it's only used in a very regular way (printing A4 and scanning A4 with only plain 80g paper). It's both on printing and copying. Haven't checked anything so far because I didnt know what to check. I was more or less expecting it to be some calibration thing....
          • Synthohol
            Certified Konica Expert
            • 5840
            looks like the paper in the tray has been pushed back from slamming.
            same from all trays?
