C2060L
  • kenpio
    • Dec 2015
    • 201
    [CQ] C2060L
    So I have a customer that has this model. It was about 2 months ago that I replaced the black developer unit and developer. Well it happened again. The black developer went bye bye. The developer count was not even 1%. I know that these should be good for 1.2 million. Any input would be helpful, because there is nothing on KM website.
    KEN
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    Re: C2060L
    Heres what i would do. remove process carriage. check what the toner looks like on the developer roller. consistency wise. if it looks fine. Goto service mode run the k in the test mode at 255 stop the image before the transfer. Remove process section again does it look good on transfer belt. What you could be experiencing is something other then a developer issue. Let me know what it looks like on transfer belt though. If you could stop it on drum as well. It will let us know where the problem is happening
    • tulintron
      • Jul 2014
      • 668
      Re: C2060L
      I agree with Mikeena, but I should have inverted the cargo corona and drums. It could be the black loading corona, lack of grounding on the black drum. Can you notice the presence of developer in the prints? Does the black drum have a developer?
      • wjurls
        • Feb 2017
        • 498
        Re: C2060L
        Looks like fairly heavy black coverage could be depleting the toner/carrier, faster than it's being added back in. Try setting dip switch 163-0 to a 1 to increase toner addition interval. There may be a sacrifice in productivity because it may also slow down printing during the add process.
        • kenpio
          • Dec 2015
          • 201
          Re: C2060L
          Let me clarify the two prints that I have in the example. The solid black one is a test print of solid black at 255. The bottom green print is their print that the were printing. I was able to stop the print and looked at the transfer belt and the black drum. That is what led me to the developer. I could see that pattern on both the TB and the drum. This customer, I don't think is too much into speed, they are an hour away. So the next time I am there I will change the 163 dip switch.
          KEN
          • mikeena
            • Mar 2007
            • 220
            Re: C2060L
            olk so heres where you conclusion has lead me. Transfer belt Has bad image. Drum has bad image. If you currently just replaced developer and dev unit. then the issue would be a arc or dev unit. now yes you just replaced the dev unit and the only reason i say this, is beecause i know a while back there was issues with dev units on a different model. i dont believe it is the issue here as this problem was a while agpo and on a different model ill look to see though if i can fine anything. i just didnt want to leave it out as a possiability. one question did this issue start after a black dev change? maybe dev is old it does have a shelf life. Arc seems more realistic though.
            • allan
              RTFM!!
              • 5462
              Re: C2060L
              Change out your main charge corona just as a precaution.
              It should not be chowing the developer like that.
              Whatever
              • mikeena
                • Mar 2007
                • 220
                Re: C2060L
                i agree i actually did have one do a similar issue. i didnt even think about that
                • mikeena
                  • Mar 2007
                  • 220
                  Re: C2060L
                  so were you able to fix it or still having issues
