Fiery IC-420 duplex printing
  • mascan42
    • Oct 2008
    • 484
    #16
    Re: Fiery IC-420 duplex printing
    We were able to resolve it by downgrading the driver to an earlier version. But now it appears to have come back. Does anyone know if the Fiery driver still has automatic updates?
    • Synthohol
      Certified Konica Expert
      • 5820
      #17
      hey, where did you get the driver from? the fiery itself or the internet?
      99% of the time i use the one built into the fiery so i know its compatible.
      maybe you installed a newer or older version of sys software than their driver?
      • drowranger
        • Jul 2015
        • 122
        #18
        Hi, still has automatic updates and annoying updater popup. need to untick notification ar driver properties> About>Check for updates>preferences(bottom lhs )
        You need to use the the fiery driver uninstaller to remove the new driver before downgrading as well.
        • mascan42
          • Oct 2008
          • 484
          #19
          Finally got EFI support on the line & they said it's a known problem with the way the driver interacts with Windows. EFI apparently has no plans to fix the driver, because they blame Microsoft, and vice versa. Only workaround was to create 2 copies of the driver, one for 1-sided & another for 2-sided.
