PC410/415 lift wires
  • Zesti
    • Jun 2009
    • 308
    #16
    Re: PC410/415 lift wires
    GREAT MINDS AT WORK.......Thumbs up....
    • femaster
      • May 2011
      • 1519
      #17
      Originally posted by drowranger
      This post have jinxed me and i found this one ... broken front holder lead to this. Awaiting for the wire..
      [ATTACH=CONFIG]47217[/ATTACH]
      Looks terrible! Never had an issue like that thankfully. Maybe I should say, yet...
      • rrrohan
        • Sep 2011
        • 1977
        #18
        Originally posted by Synthohol
        done exactly that 4 times.
        i use my spring hook tool to wedge it in the groove.
        i gotta find some old bh600 rubber corona holders, that sounds like a good fix as well.
        The part can still be ordered from KM, I asked the other day
        Sent from my Pixel 4 XL using Tapatalk
          • 23010
          #19
          Off topic: Kyocera sold a ledger/A3 sized external paper deck PF-660 for the KM-8030. Almost every customer I had with one of these eventually loaded two stacks of letter on the lift tray. Naturally the paper deck can only take paper off the left stack. Once it had used about 50mm of the left stack, the right stack was pressed very tightly up against the top of the deck, and the right cables would snap like over-tight guitar strings. =^..^=
          • suomi
            • Oct 2008
            • 152
            #20
            Originally posted by MVPunisher
            All of these better ideas than mine. But I have fixed this on the fly by wedging the perfect size tiny piece of paper.... folded up tight (real tight) in the groove. Just the right size to not obstruct cable but folded tight enough to not pop out. Didn't get a call back. Done it twice.
            Works when you just put something in the gap.
