BH-C-360, water drops in fuser
Re: BH-C-360, water drops in fuser
I'd imagine that the lowest rated 40C, mounted to a metal frame member in the bottom of the machine would be quite adequate (doesn't show resistance or wattage specs).If you'd like a serious answer to your request:
The tray heater for the Konica Minolta machines have only 2 wires going to it.
That comes from an step down transformer at around supplying from 20 to 24V AC.
Guess its got regulation and protection included in the element somewhere.
Or its just a low wattage.
Instead of buying just strip out of B600 or any other scrap machine that includes a tray heater.
Strip out the element pad and the transformer.
Used those for on a incubator before. Also used them one winter to heat up my feet.
But doubt the source of moisture here is from the paper.Last edited by allan; 11-19-2020, 10:06 AM.WhateverComment
