TCR Sensor C7000 vs C6500
  • wjurls
    • Feb 2017
    • 496
    Does anyone know if a TCR Sensor for a C7000 will work in a C6500 as well? They are different part numbers, but I'm hoping it's the same basic sensor.
    Thanks, Lee
    Re: TCR Sensor C7000 vs C6500
    Thanks, Lee
    i doubt it
    • wjurls
      • Feb 2017
      • 496
      i doubt it
      Me too. Just hoping so. I have a customer who needs one for a C6500 and I will already be in their area tomorrow and I have a new C7000 dev unit, but not a C6500 TCR.
      • rrrohan
        • Sep 2011
        • 1977
        I don't do production but if I had the parts guide I'd just see if PN are the same
        Sent from my Pixel 4 XL using Tapatalk
        • Toxic
          • 697
          You should try it, they can be the same thing.
          Recently have problem on C6000 and replaced transfer roller HV wire from C5501, i think whole transfer belt is totally the same and some more parts for sure.
          BTW i use DU104 (C6000,7000) for years on C5501.
            IF the toner formulation is not the same the TCR sensor has to be different
            • Toxic
              • 697
              Agreed,I just google both sensors,they look same except different connector.
              Just searched,it seems toner is the same compound.
              • tsbservice
                Field tech
                • 8018
                Aftermarket toner sensors seem to fit both press.
                Konica Minolta Toner Sensor A1DUM50800 bizhub PRESS C6000 C7000
                  well we all know how much KM's like aftermarket toners...
                  even with the connector being different I wouldn't trust trying to fit one in.
                  • Toxic
                    • 697
                    This look like OEM tcr sensor but for C6000,7000 , i dont see anywhere they clame to fit on C6500...
                    • tsbservice
                      Field tech
                      • 8018
                      Phil you are right on aftermarket toners. My guess is both machines use same toner formulas I just hopefully seek for evidence he can use what have in hand.
                        didn't think it would.
                        • tsbservice
                          Field tech
                          • 8018
                          Oops, seems I missed the main plot...sorry guys
                          • Toxic
                            • 697
                            Toners are the same compound so sensors are propably the same except connector.
                            If i would in some emergency situations i would just replace connector and fit.
                            On the field i have to improvise so many times sensors,termistors,heater lamps,clutches... with just different connectors or similar small difference to back machine to working condition without waiting for original part.
                            • tsbservice
                              Field tech
                              • 8018
                              Exactly my thoughts. Still You and Phil are correct on topic.
