TCR Sensor C7000 vs C6500
  • tulintron
    • Jul 2014
    • 668
    #16
    Re: TCR Sensor C7000 vs C6500
    I have already replaced it a few times and I can say that it works. Just cut the wires and solder to the correct connector. The connections are different, but the sensor is the same. I can assure.
    • wjurls
      • Feb 2017
      • 498
      #17
      Thanks everyone for the input. I managed to get the correct TCR sensor in time for the service call. C6500 and C6000 use the same developer so I assume that the toner would be the same. In this case, the problem turned out to be defective developer (assuming customer did exactly as claimed prior to error). New sensor still threw immediate code C-2453. Dumped old DV and replaced with new and all was well. I will have to remember the connector modification for future problems.
      Lee
      • tsbservice
        Field tech
        • 8018
        #18
        Lee
        Thanks for follow up Lee 👍
