Random C1102 FS533 on Bizhub 308e
  • Bix
    • Apr 2018
    • 1421
    Hi, I have a bizhub 308e with an FS533.
    Sometimes, during the day, the printer reports C1102. This mistake is not new to me. Last time I just unplugged and reattached the PS107 sensor and it started working again.
    The error occurs when the paper tray goes up. So the theory that it could be PS107 convinces me more and more. In my entire career as a technician, motor has never failed but there is always a first time.
    This time it's a very distant customer. My idea is to arrive with a new sensor. But I take this opportunity to ask you for a consultation.
    Thank you!
  • Genotrom
    • Feb 2020
    • 77
    Re: Random C1102 FS533 on Bizhub 308e
    try to check the movement of the tray from the service menu
    • Bix
      • Apr 2018
      • 1421
      Yes, I have already tried. This could work for hours and stop suddenly.
      • allan
        RTFM!!
        • 5462
        Looking at the manual the sensor makes the most sense.
        Unless you customer is doing something stupid that stops it from moving up like pressing on it.
        Having a look at the drive gear train would be good. Will only take one missing tooth from one of the gears or belts to upset it.
        There is a bunch of gears in that train.
        Looks like it could be possible for the one side to slip a tooth or two on the belt making the tray skewed.
        Whatever
        • Bix
          • Apr 2018
          • 1421
          Excellent reflection allan.
          Thanks!
          • kaisa
            • Sep 2019
            • 9
            Hey ich habe die gleiche Fehlermeldung an einer C250i. Wie hast du das Problem behoben ?
              • 22999
              These internal finisher look a lot like the Toshiba internal finishers. Often customers would put paper under the receiving tray while the tray was up, and it made the sensor unhappy. I've also found strips of Swingline staples that the customer was tryng to install, but it was never going to happen. It was rare to catch the customer doing it. =^..^=
