C454e Printing not fusing and with shadows
  • positiveg
    • Jun 2018
    • 299
    Good day
    I'm attaching a photo of prints we are now getting from our printer.
    Don't understand but the images are not fusing no matter what setting thickness of paper we use
    and we are also getting like a double line around the images
    please see
    WhatsApp Image 2020-11-11 at 11.45.42 AM (1).jpgWhatsApp Image 2020-11-11 at 11.51.57 AM.jpg
    • 30264
    Re: C454e Printing not fusing and with shadows
    What's the paper type?
    • timelmrep05
      • Feb 2018
      • 13
      I would start with cleaning the image density sensor .. Remove the transfer belt and clean the sensor .. Had this issue at a customers .. the sensor was filthy so would set the density correctly and added too much toner to the pages and would fuse correctly .
      • positiveg
        • Jun 2018
        • 299
        32lb stock
        • positiveg
          • Jun 2018
          • 299
          Ok will try that and let you know.
            • 30264
            what does do with plain paper
            • positiveg
              • Jun 2018
              • 299
              the exact same thing
              it like plain regular paper and that's what we get
              so it's not even like coated or cover stock paper.
                • 30264
                How many copies on the fuser and what does it look like.
                did you stop the paper before the fuser is the image blurred?
                • positiveg
                  • Jun 2018
                  • 299
                  Fuser has less than 25k copies, I 'll have to stop the print before fusing to check if it's blurry.
                    • 23008
                    This isn't a fusing issue, it's color registration. You need to do stabilization and gradation.
                    And if you mean 32#BOND or 116gsm, you'll want to use Thick1 media type for proper fusing. But just to be very clear, this is not a fusing issue, it's a color registration issue.
                    • positiveg
                      • Jun 2018
                      • 299
                      yes we use thick 1
                      same issue
                      ok Registration
                      and how di i fix that?
                      • copytechman
                        • Nov 2008
                        • 945
                        If it definitively is not fusing are you using OEM toner?... I ran into that intermittently with a C258. Found out it had aftermarket toner in it...
                        Good times.
                        A.
                          • 16395
                          Originally posted by positiveg
                          yes we use thick 1
                          same issue
                          ok Registration
                          Do you have a manual for this machine?
                          • positiveg
                            • Jun 2018
                            • 299
                            Yes. Bought one thanks
                            Sent from my SM-G955F using Tapatalk
                              • 23008
                              Ok, now you can begin to read the manual. You should start at the part about stabilization and gradation. =^..^=
