Bizhub C-458, panel unresponsive..
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys... So, I've had several machines do this and rebooting is the only way to get the control panel to function again. The panel comes up just fine and the machine works normally as a printer, etc. but icons cannot be pressed. I've tried replacing the HDD with no luck. I also removed and reinstalled the SSD Board, no luck there either. Has someone fixed this problem and if so, what did you do? The firmware is up to date, the machine has been reinitialized and hard drive PHYSICALLY formatted, several times.
    Thank you in advance!
    OC
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Bizhub C-458, panel unresponsive..
    OC
    Its the control panel replace complete control panel I've had it 5 times
    Regards Mark
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      Yep, we've had it a few times as well.
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • Synthohol
        Certified Konica Expert
        • 5823
        may sound silly but have you tried re-seating the video cable to the panel and mfp board a few times in case it has a bad contact?
        or calibrating it if you can get it to work long enough?
          • 23007
          Also free, you could try uninstalling Marketplace. That uses a lot of resources, slowing the panel reactions. =^..^=
          • rrrohan
            • Sep 2011
            • 1977
            I've got one that has same issue but if you quickly tap the screen it will eventually register it
            Sent from my Pixel 4 XL using Tapatalk
            • Bix
              • Apr 2018
              • 1421
              Hi, I have had this problem.
              The solution was to replace the complete control panel. In service mode there is often an C-4091, FA-14 or E301
