E206 on setting up a new C3350
  • soaponarope
    Pat McGatt
    • Nov 2020
    • 30
    [Error Code] E206 on setting up a new C3350
    No error code listed in manual. Do you know what it means?MicrosoftTeams-image.jpg
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: E206 on setting up a new C3350
    i assume by the pic its a C3350i
    probably trying to reach marketplace.
    see if it can be disabled.
    i didnt see anything in the manual either so thats my best guess.
    • soaponarope
      Pat McGatt
      • Nov 2020
      • 30
      Yes i ​machine.
      • soaponarope
        Pat McGatt
        • Nov 2020
        • 30
        Situation is slightly different now. Error has gone, machine works ok. However after about a minute the display goes off and the whirly-gig symbol appears. If you touch the screen it comes back and works fine. A bit like an energy save situation but it isn't and energy save settings have no effect. It looks as though it is trying to load something...
        • Synthohol
          • 5846
          It could be running the marketplace screensaver
          • soaponarope
            Pat McGatt
            • Nov 2020
            • 30
            OK. How do I get rid of that?
              • 14791
              To disable the MarketPlace screen saver perform the following:
              1. Enter the Utility> Administrator mode
              a. default password is 1234567812345678
              2. Select System Settings
              3. Select Reset Settings
              4. Select System Auto Reset
              5. Turn the Screen Saver Function toggle to O
              • copier tech
                • 8170
                No error code listed in manual. Do you know what it means?[ATTACH=CONFIG]47347[/ATTACH]
                I had a similar issue.
                Look at the error history in CE mode, mine logged C2204 yet error on the on screen was E201.
                • Synthohol
                  • 5846
                  thats damn good advice right there!
                  • soaponarope
                    Pat McGatt
                    • Nov 2020
                    • 30
                    You 3 have been really helpful and I will try your suggestions tomorrow and let you know how I get on. This is the first time I have raised a thread on here and am impressed. Minolta themselves do not know what that code means...
                    • soaponarope
                      Pat McGatt
                      • Nov 2020
                      • 30
                      This resolved it so thank-you very much copier addict!
                      • copier tech
                        • 8170
                        Thanks for the for the feedback i've also not heard back from my client after turning off the screen saver & marketplace up.
                        However not sure why this would throw an E code error not in the manual.
