c284 firmware woes
  • copiertec
    • Jan 2016
    • 2211
    c284 firmware woes
    I'm sure you Konica techs are tired of this series being posted concerning firmware, so please, bear with me as I am not adept on these boxes concerning firmware. We had a c284 with firmware ver. GD1-A9, I was under the impression that this was old firmware, so I installed G00-72 ( I should of just left it alone I know better!) Now the client can't scan to email with any encryption (ssl, tls) and it wiped out the account codes on top of it.
    What did I do wrong? What can I do to fix it? Any help would be grateful.
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: c284 firmware woes
    there was special firmware (A9) that made the "non e" model do the same as the "e models"
    yeah that was a mistake.
    never touch firmware on a konica unless you are addressing an issue. if it aint broke, dont fix it.
    i know it was an honest mistake but kind of a rookie move .
    • copiertec
      • Jan 2016
      • 2211
      I'm with you, synthohol, it's not my first rodeo and thought the same thing before updating it. I kicked myself mentally for doing it because my instinct told me to leave it alone. Any suggestions to fix what I FUBARED?
      • copiertec
        • Jan 2016
        • 2211
        Is it possible to downgrade the firmware back to GD1-A9 at this point? Or is that too old of a firmware?
        • Synthohol
          • 5892
          not so much as a downgrade but it tricks the machine into the capability and security level of the e series.
          i tried to DL it but 2 browsers loop back to the main page when i select one stop support.
          i think the site is under maintenance.
          • copiertec
            • Jan 2016
            • 2211
            I appreciate your help, Synthol. Keep me posted on any solutions you may have, uhhgg.
            • Max
              • Oct 2011
              • 566
              Just delete current certificate and install a new one self signed. Make sure all types of encryptions are ticked under security tab. If needs be drop to normal firmware instead of special. Check machine and type are correct too when installing firmware.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Just a tip:
                any old 4 series running the special version up firmware should have a sticker or some such advising of the special firmware installed on the machine near the service port so such mistakes dont happen.
                There is much newer than that version up fw you were running anyway and the usual suspects that sell firmware on here could probably help you out
                • copiertec
                  • Jan 2016
                  • 2211
                  We tried deleting the certificates and installing new ones, no go. What we may do at this point, is replace this mfp with A) a newer machine B) replace it with an e series and be done.
                  • tsbservice
                    Field tech
                    • 8053
                    There is specific procedure (see attached) to make them an e-series. You will need GB0-A9 and GBF-M0 firmwares, I feel a bit guilty as I may mislead you...unfortunately I don't have access to them.
                    • copier tech
                      • 8202
                      I did exactly this at a real estate agents!
                      It was an easy fix, simple re-install the 'version up firmware'
                      • copiertec
                        • Jan 2016
                        • 2211
                        No worries, tbs, things happen. I honestly knew better as I was on the fence about this series and everything was fine with it, I shit the bed when I seen it come back up with no account codes, then no one could scan to the email as it wiped out all the email setup. We replaced it with a loaner until we come up with a solution, either we get the above mentioned firmware from a kind soul here on CTN, or we upgrade them into a newer mfp.
                        • copiertec
                          • Jan 2016
                          • 2211
                          Ditto, however we do not have the version up firmware.
                          • copier tech
                            • 8202
                            Here ya go I feel your pain bro!
                            • copiertec
                              • Jan 2016
                              • 2211
                              Thank you, copier tech, much appreciated!
