[Need Help] empty lines on printed document
    • 23009
    #16
    Re: [Need Help] empty lines on printed document
    I guess that I have to point out here that the laser slit glass and the scanner slit glass, though performing a similar function, are two entirely different items. I really hope that this is result of a questionable translation, because if it isn't you have a long way to go to become a technician.
    • CP-1015
      • Nov 2020
      • 323
      #17
      Hi,
      1. Clean Laser glass not scanner glasses
      2. Change Developer. Because it seems it is not realy black, only grey and foggy and somebodey wrote it already: There is something under Doctor plain (white lines).
      3. Change drum and main wiper (together with developer)
      • copiray
        • Feb 2019
        • 29
        #18
        Originally posted by Omar Faris
        i dont think that the laser glass is dirty because scaning to pc gives good image, and printing from pc gives the same problem, so it's not the scaning laser glass problem
        thanks for the idea
        the laser has nothing to do with the scanner, remove the developer unit, if the developer is uniform throughout the magnetic roller, the problem has to be in the laser glass, remove the drum and check that the laser glass be clean
        • copiray
          • Feb 2019
          • 29
          #19
          Both mentioned already. Pls try harder.
          I have only given my opinion of the problem and I have requested more information, I do not understand the negative reputation
          • greglogston
            • Jul 2018
            • 34
            #20
            Originally posted by Max
            Dirty laser glass? Try the magic wand.
            For a bizhub 350? Don't think that is correct.
            • greglogston
              • Jul 2018
              • 34
              #21
              Hello,
              i need some help about my Konica Minolta Bizhub 350
              The problem is that all the printed documents has a two or more empty lines,
              i have added with this post a picture of the problem,
              any reply will be appreciated.
              My guess is that the felt behind where the drum and developer sit is falling apart and covering the printhead in a couple spots. Or the developer and/or the developing unit need replaced. My best bet is the felt is obstructing the printhead.
              • greglogston
                • Jul 2018
                • 34
                #22
                You mean printhead ? And don't think there is a wand for the bizhub 350. Just good old fashioned manual cleaning.
