Can I fill a toner cartrige c308 with the old one c284e ?
  • Francy
    • Nov 2020
    • 3
    [Misc] Can I fill a toner cartrige c308 with the old one c284e ?
    Hello,
    I bought a new photocopier Konica c308 but i have some toner cartridge of my old Konica c284e (TN321x) to reuse.
    Probably the toner container is not compatible with the new c308, I don't know.
    Anyway I ask if it is possible to refill the cartridges of c308 (CYMK) with the old toners of c284.
    Thank you
    Francy
    • 22698
    Re: Can I fill a toner cartrige c308 with the old one c284e ?
    Let me be the first to say that this is a really really bad idea. If yo decide to do this, remember that I advised against it.
    • joelea
      • Feb 2012
      • 64
      Originally posted by Francy
      Hello,
      Thank you
      Francy
      The c308 uses a different charge assembly on the drums than the c284 so I wouldn't recommend doing this, you may end up with at best a dev & drum unit failure or at worst a broken main drive unit.
      • copier tech
        • 7931
        Hello,
        Thank you
        Francy
        As others have said not a good idea, however I have done this on a number of occasions without any issues (none)
          • 14752
          When I was in the toner cartridge rebuilding business, I found that HP used the same toner for about 10 different cartridges. We would order this toner in bulk and it saved us a lot of money compared to ordering the individual bottles that had the correct grams. The only problem is we had to weigh out the correct grams which was a pain in the ass.
          With all that being said...you have no idea if this is the case in your situation. You're playing Russian Roulette. I wouldn't chance it. No way.
          • copier tech
            • 7931
            I’ve already taken this chance multiple times as I said with no issues.
            As a test just try one colour maybe on an old/scrap model first, worst case you’ll only kill one dev unit.
              • 14752
              Hey, as long as he understands the risk involved, I've got no problem with it. Go for it.
              • allan
                RTFM!!
                • 5445
                Works no problem. Same toner...
                If the machine replenish developer you will see a port from the devtank going into the waste box.
                In that case for K TN216/319 TN321/512 TN514 TN613/712 all the same.
                Take a teaspoon of developer from DV512 and TN414 and that will work just fine too but don't really recommend that for color machines, b/w no problem.
                If you use non developer containing toner like TN414 expect the devtanks to fail before 300K...
                The color CMY you can F*$#%up badly if you put developer containing toner in a non replenishing machine like a C287 or even a C360.
                For the C287 TN216/319CMY or even TN613CMY works just fine.
                Some KM toner works great on Xerox color....
                All at own risk been doing this for some time.
                Been feeding my 951's katun TN414...
                To answer yes it will work but...
                Whatever
                • copier tech
                  • 7931
                  I had a few C224e series that would keep depleting the developer, so rather than replace the dev unit each time at high cost so with nothing to loose I topped then up using old dev I tipped out from C552 image units, to my surprise it worked perfectly! I still use this method today using old C654/C764 image units.
                    • 14752
                    I hear ya and I trust what you say. But you're a trained tech. I think this is an end user?
                    • copier tech
                      • 7931
                      Ah yes if this was an end user with a 'new' C308 might not be worth the gamble.
                      • allan
                        RTFM!!
                        • 5445
                        Hey if OP is a end-user and screws up. Means money for a tech out there...
                        Agree sell you toner on the old interweb then buy the right stuff if you don't want to take risks.
                        Easy sell.
                        Whatever
                        • tsbservice
                          Field tech
                          • 7635
                          This is so bad BAD thread in many ways!
                          Just imagine next non contract machine you're working on has customer filled toners with whatever left on the shelves they think can put in. Sure some may pick out adequate cartridge...but how many?
                            • 14752
                            Yeah, imagine being callrd out on a service call and they have the right cart installed but you have no idea they refilled it with toner from a different model. You'd be chasing your tail for a while. lol
                            • tsbservice
                              Field tech
                              • 7635
                              That was what i meant. Easy to screw even experienced techs not to mention novice.
