Faded on edge
  • positiveg
    • Jun 2018
    • 299
    Faded on edge
    Hey guys I'm getting some colour fading in the edge of my 12*18 prints
    Please check this scan image please.
    Check k out the green bar on the top and bottom set of labels.
    Think could be the IBT or the fuser?
    And I did Ave a line running through. Thought came from the yellow drum so I changed it. Don't seem like it was that drum.
    Sent from my SM-G955F using Tapatalk
    Re: Faded on edge
    need it in PDF format
    what are the life counts on the drums/dev units?
    OEM genuine Toner/drums/devs?
    direction of feeds on the PDF examples?
    did you try a copy of the example? different issues?
    what are the life counts for fuser/ITB?
    what media is being run?
    is the media properly setup on the unit trays?
    what tray are you feeding from?
    Phil B. ' The Dentist '
    • positiveg
      • Jun 2018
      • 299
      Re: Faded on edge
      All genuine drums and to ers.
      Fuser on 38% got to check te count
      Black drum 96
      Yellow drum just installed today M, C 96%
      Ita an adhesive vinyl 4 mil stock running from trya 5.
      See I was gonna save the scan in Pdf and was like nope jus in case would get asked for it in JPG.
      Lol
      • CP-1015
        • Nov 2020
        • 318
        Re: Verblasst auf Kante
        Hi, already calibrated?
        • copier tech
          • 8144
          Re: Faded on edge
          Black drum 96
          Lol
          Swap round the yellow & magenta drums around see if this 'moves' the issue.
          • positiveg
            • Jun 2018
            • 299
            Yeah, but I'll run another
            • positiveg
              • Jun 2018
              • 299
              Re: Faded on edge
              Ok cool will give this a shot and see
                • 23007
                Re: Faded on edge
                This is not the easiest sample to use for color differentiation, but from what I can tell all the colors are ~40% less density across the board. So ... IF there is a single cause, it's a problem affecting all colors equally, i.e.: primary or secondary transfer, or maybe all of the laser slit glasses equally dirty at the rear. It's unlikely that all the imaging units are experiencing the exact same fault in exactly the same location.
                If you'd like specific advice, you might tell us what model of machine that you have.
                Make it easier on yourself! Use a print sample using CMYK base colors like this:
