Anyway to stop finisher sorting after each job Konica c308?
  • fishleg
    • Mar 2009
    • 426
    We have a kinda nightmare where a customer needs a finisher for one job so they can staple and then they don't need it for another job and just need speed.
    The ideal is two printers but they won't spend money...
    They print a report which is generated by bespoke software problem is it's generated as single 1 page jobs which are 600+ pages big. So machine prints then pauses paddles come in and out then job continues next page out paddles come in straighten stack and continue... This slows the machine down to 10-15 pages a minute.
    Is there anyway to change how often it pauses to straighten the stack on finisher or anyway to make it see multiple single page jobs as one job?
    Hope that makes sense.. thanks for any help.
  • Synthohol
    Certified Konica Expert
    • 5912
    Re: Anyway to stop finisher sorting after each job Konica c308?
    isnt there a setting for continuous print? i know on production machines there is.
    • KMFLT3CH
      • May 2017
      • 242
      Does it align each page one at a time and then push the pages out as a stack, or does it spit out each page completely before moving onto the next page?
      Try going into Admin mode > System settings > Output settings > and turning off Shift Output Each Job.
      Alternatively you can set Prints to come out on the top tray, and Copies on the bottom tray (Output Tray Settings, same menu as above). When they use the staple function for their other job, the machine will know to use the bottom tray. When they go to print out their reports, it will spit them straight out, no sorting, into the top tray.
      • femaster
        • May 2011
        • 1527
        I was going to suggest your second idea, but the problem with that is, the top tray isn't going to hold the 600+ pages he said the job prints. I'd give the first suggestion a try though and see if that speeds things up a bit.
        • fishleg
          • Mar 2009
          • 426
          Yeah I found that shift output and turned it off didn't make a difference and yeah the top tray wouldn't hold enough sheets.
          Each job is an A5 barcode and it holds 1 page in the finisher paddles come in then it spits the single page out and starts again. Each page of this report is in the job list so there's 600 jobs all 1 page. It feels like because the finisher has to do the hold, adjust, straighten and eject each sheet it adds on atleast 4 seconds to each page being printed.
          I'm guessing there's no way to get the finisher to just spit out single sheets don't hold them in the finisher? The way the machine is printing 1 A5 is going through at any one time instead of the usual 3-4 sheets going through at different points in the paper path.
          I think it's gonna have to be you need a second machine for this job can't seem to win...
          • occus
            • 339
            Maybe i don't understand your problem but it seems to me that you need a job merging tool to collect all jobs in one job.
            In one job the printer goes forward and don't have to wait for passing the last sensor on finisher.
            Fineprint can do that.
            • emujo2
              • Mar 2017
              • 1579
              Utility]
              • [Administrator]
                • [System Settings]
                  • [Output Settings]
                    • [Print/Fax Output]
                  • Try setting to batch printer..This worked on many older models..E
