Restart 454e
  • uzi mana
    • Jun 2012
    • 20
    Restart 454e
    HII
    i have two machines 454e and thay Restart several times and then rising When I turn off power completely and turn it on again they repeat the startup several times and then stabilize without a problem What needs to be done for a machine to stop booting?
  • Gift
    • Mar 2011
    • 2459
    Re: Restart 454e
    Probably it's a faulty ssd board or hdd issue.
    • copier tech
      • 8132
      Re: Restart 454e
      Originally posted by uzi mana
      HII
      If the machine comes to ready after you power off & on its not the SSD.
      Check the error history most likely C-2557 etc errors logged.
      • uzi mana
        • Jun 2012
        • 20
        Re: Restart 454e
        I replaced and did not help
        • copier tech
          • 8132
          Re: Restart 454e
          Did you check to see is any errors are in the history?
          • Gift
            • Mar 2011
            • 2459
            Re: Restart 454e
            Both? OK, try and see if the error comes up if the network cable is unplugged.
            Another thing what comes in my mind is the PSU. Does the machine collapse right in the moment when the print engine starts it's idle-initialisation run?
            You can try and start the machine with an open door to see what happens without the additional load from fuser, maindrive, fan etc.
            • uzi mana
              • Jun 2012
              • 20
              Re: Restart 454e
              [QUOTE=Gift;1636399]Both? OK, try and see if the error comes up if the network cable is unplugged.
              You can try and start the machine with an open door to see what happens without the additional load from fuser, maindrive, fan etc.[/
              i did and did not helpThe machine is not connected to the networkOnly copy
              After she finishes doing a restartIt works without a problem and also prints
              • uzi mana
                • Jun 2012
                • 20
                Re: Restart 454e
                no eror
                • Bix
                  • Apr 2018
                  • 1421
                  Re: Restart 454e
                  Hi, sure they're not connected to a faulty power strip? They have maximum power parameters. Is there a UPS? Is the ethernet cable powered?
                  • uzi mana
                    • Jun 2012
                    • 20
                    Re: Restart 454e
                    no ups and I took them to my lab
                    • tsbservice
                      Field tech
                      • 7989
                      Re: Restart 454e
                      Do Clear All Data in service mode.
                      • uzi mana
                        • Jun 2012
                        • 20
                        Re: Restart 454e
                        I exchanged memoryI replaced nvramI replaced h.d.dAnd still did not get along
                        • allan
                          RTFM!!
                          • 5462
                          Re: Restart 454e
                          Ok so as mentioned before will remain on if you leave the side door open?
                          Take a video of the machine starting up. That could help.
                          Whatever
                          • uzi mana
                            • Jun 2012
                            • 20
                            Re: Restart 454e
                            Tomorrow morning I'll go up to a video site
                            • uzi mana
                              • Jun 2012
                              • 20
                              Re: Restart 454e
                              454e.mp4 - SendUp
