Blue toner on edge of large paper prints
  • positiveg
    • Jun 2018
    • 299
    [Misc] Blue toner on edge of large paper prints
    Hi there guys this is the C454e
    printing now
    i am not sure why it's happening
    So some help would be appreciated.
    Google Drive: Sign-in
  • positiveg
    • Jun 2018
    • 299
    Re: Blue toner on edge of large paper prints
    Was trying to upload image or link via computer no luck. So using the the app
    Sent from my SM-G955F using Tapatalk
      • 16406
      What have you done to resolve the problem?
      Total counter?
      PM counter?
      • dibyendu2008
        • Dec 2011
        • 27
        in color or garyscale mode mode this blue lines are coming? please check any voltage aching or leackage in Imaging unit. what is the life of all imaging units?
          • 16406
          My best guess would be drum/drum blade. It would help to know how many pages have been printed on the PM parts.
          • Synthohol
            Certified Konica Expert
            • 5846
            If I am to assume that was printed short edge first, I'd print portrait to get a clear view of what's happening.
              • 16406
              I got $1 that says it was printed short end first. Bet?
              • Reed
                • Feb 2011
                • 258
                printing now
                Normally I would say drum. Did you swap out the drum with another color drum?.. Did the issue follow the drum?... If not, definitely pull the DV unit and check it out. Something is causing that Cyan to pull like that
                Sent from my SM-G955U using Tapatalk
                • CP-1015
                  • Nov 2020
                  • 323
                  First I would clean PH glasses. Than I would have a look to the drum.
                  • tsbservice
                    Field tech
                    • 8020
                    Do exactly what Reed said. What is the distance, if print is SEF and has gritty feelings then definitely take a good look at developer unit.
                    • Albonline
                      • Sep 2008
                      • 1151
                      The root cause of this is usually. the black unit misting ,fouling cyan charge system.
                      • Synthohol
                        • 5846
                        It's a repeating pattern on the drum. It's the drum.
                        • Firmaware
                          • 30
                          You must change drum and developer and set TCR value for cyan -2
                          Gesendet von meinem SM-G980F mit Tapatalk
                          • Toxic
                            • 698
                            Obviosly its damaged drum, same mark is repating.
                            Measure distance betwean 2 same marks and if it is arround 95mm it is drum for sure.
                            • tsbservice
                              Field tech
                              • 8020
                              94mm to be precise
