C364 e printing problem
  • blinxwap
    • Jun 2020
    • 80
    I have a c364e firmware A5C10Y0-F000-G20-M1
    Printing from usb and netowork the nobs gets stuck in que doesnt print have disabled firewalls and anti viruses on 2 pcs restarted print spooler documents prints sometimes other docs or images file size increase if its 2mb it might show 97mb in the que loads ful but doesnt print
    Sent from my SM-A505F using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: C364 e printing problem
    open pswc and print test pages from there to eliminate the controller as the issue.
    • drowranger
      • Jul 2015
      • 122
      please make sure hdd is turned on ( service mode > System2>) and spool print jobs in hdd setting is on ( utility>printer settings>basic settings>) as well.
      • tsbservice
        Field tech
        • 8020
        Hey drowranger, your posts are quite helpful. Go for more mate 👍
          • 23009
          You can try to ping the printer, or connect a laptop via crossover cable. Perhaps you've got a duplicate IP address? =^..^=
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            If its a second hand machine and had overwrite all data performed item number 2 in your suggestion does get turned off and people forget to turn it on again
            • CP-1015
              • Nov 2020
              • 323
              Re: C364 e Druckproblem
              Maybe I don't understand correct, but if problems with pdf-files print as picutre.
              • blinxwap
                • Jun 2020
                • 80
                I just got off the phone with the customer upon our coversation previously i asked that he should take a completely different laptop preferably and connect it to the printer via usb and network, he did and everything printed fine to my conclution it is his 2 desktop pcs that are at fault operating systems i also found the customer is building his own pc with upgrades and has alot of programs and games running on the desktop pcs that might cause the printing problem am i correct
