I buy several used Series 4 printers. All of them (bizhub c284e, c364e, c454e) very often have one problem in common: tray 2 jam. Replacing the rollers does not solve the solution. The paper jams a few centimeters after the rollers.
The solution is to clean the gray rollers but in some cases, it is not a permanent solution. Someone advised me to replace these springs but I wanted to know if you have had any experience. Thanks!
