BH-423, C-C211
  • Hansoon
    • Sep 2007
    • 3347
    BH-423, C-C211
    Guys I hope you all have a save and merry Christmas 2020 and that Covid is not hitting you.
    I got from a wholesaler an extremely clean BH-423 with only 22.000 (!) prints on the mechanical counter. The whole machine looks as completely new depending on the state of the drum unit, the rollers, the fuser unit etc. So I believe the 22K are true. However, some ass seemed to play with the NVRAM and when the machine fires up after short time error code c-c211 appears. I removed the hard drive as well as ADF, extra cassettes unit and Fax Kit. The situation stays as it is. Any ideas how to get this beauty back on its feet? Because of the very low meter I would love to make a coin operated machine out of it in spite of its relative age. Should I use the NVRAM reset tool?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • tsbservice
    Field tech
    • 7897
    Re: BH-423, C-C211
    Try to do logical format of HDD. Check that Authentication device isn't set in billing mode.
    • Synthohol
      Certified Konica Expert
      • 5724
      Re: BH-423, C-C211
      make sure vendor mode is set to unset.
      Description
      Error code CC211 shortly after power ON. This error occurs afterfailureto delete authentication data. Itis notdocumented inolder Field Service Manuals.
      Solution
      PROBABLE CAUSES:
      1. Corrupt data on hard drive.
      Perform the logical format of the Hard disk assembly using these steps.
      a. Enter Service Mode: Stop g 0 g 0 g Stop g 0 g Clear.
      b. Touch these keys in this order: [State Confirmation] g [Memory / HDD Adj.] g Memory/HDD Adj.-HDD Format.
      c. Select Logical Format (only when initially setting up).
      d. Touch [Logical Format].
      e. Press the Start key to start the formatting sequence. The sequence will terminate automatically when it is completed.
      f. Turn the main power switch OFF; after 10 seconds or more, turn it back ON.
      IMPORTANT : Formatting the hard disk will erase all data contained on it.
      2. Failure of Authentication device (AU-102/AU-201H/AU-202H/AU-204H/AU-211P) or MFPB (PWB-MFP).
      • Hansoon
        • Sep 2007
        • 3347
        Re: BH-423, C-C211
        But guys I removed and unsetted the hard drive as well as ALL options.
        Tried the NVRAM reset thingy and is giving me now in Japlish:
        "This is invalid External Memory. Please make sure the External Memory."
        Tried several USB sticks. Any idea?
        Hans
        • Zesti
          • Jun 2009
          • 308
          Re: BH-423, C-C211
          Check if NVRAM is seated correctly. Once stuck in 363 with same error and the problem was found to be the Plastics casing of NVRAM, was creating hindrance in seating the NVRAM properly.
          • Hansoon
            • Sep 2007
            • 3347
            Re: BH-423, C-C211
            Thanks, did already remove the plastic housing before because of that fear. Seems the machine is very, very dead.........
            But I won't give up!
            Hans
            • Synthohol
              • 5724
              Re: BH-423, C-C211
              can you boot into service mode? stop-9 make sure vendor mode is unset. (not looking for a card reader)
              • zoool
                • Nov 2016
                • 52
                Re: BH-423, C-C211
                this is trouble with baypass tray. isolate it in service and check it. for me is clutch
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  Re: BH-423, C-C211
                  NOPE!! Not even close.
                  Hansoon, don't pay attention to this advice (betting you already knew that). The other posts are on the right track.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • zoool
                    • Nov 2016
                    • 52
                    Re: BH-423, C-C211
                    [QUOTE=srvctec;1652508]NOPE!! Not even close.
                    Hansoon, don't pay attention to this advice (betting you already knew that). The other posts are on the right track.[/QUOTsorry. you have right. i think about c-0211...
                    you can make na nvram recovery and install latest firmware. if you need nvram recovery PM me.You can do it without firmware but for me is better with firmware.
                    • allan
                      RTFM!!
                      • 5458
                      Re: BH-423, C-C211
                      Did you get her running?
                      Whatever
                      • Hansoon
                        • Sep 2007
                        • 3347
                        Re: BH-423, C-C211
                        Yes Allan, thanks for asking and sorry I forgot to post back.
                        Did a trick with the NVRAM board. More shouldn't be posted here in public......
                        The reason for the message "This is invalid External Memory. Please make sure the External Memory." was that I was that day in "Dorky Mode" and too late realizing that USB sticks should be formatted FAT32 and not NTFS.
                        Machine is up and working "and as new" and once again another big here.......
                        Hans
